Eagle or Crower Rods?
Hello!
I'm in need of some expertise from some of you that have tried different rods. I'm building my JDM H22A to boost 20+ psi through a FMAX turbo kit. I'm debating on which brand of rods would hold up the best for this sort of application. I've seen both, and the I-Beam design of the Crower, which sort of resemble the stock rod design. However, the H-Beam design of the Eagle to me would seem to be a bit stiffer. Am I wrong in my assessment of the two rod designs? What do you EXPERIENCED builders have to say about this? Is there another brand of rods that I should consider? Thanks for the time and replies!
Peace!!!
Dan P.-
*corrected: thanx Toretto*
[Modified by 92_BB4, 11:23 PM 2/27/2003]
Peace!!!
Dan P.-
I have used Crower, Carillo and Oliver rods - my preference is the Carillo, but I have never had a rod failure with any of these rod manufacturers.
Kirk
Kirk
Actually, Eagle rods are H-beam rods. And I havenet heard of anyone having anything go wrong with Eagle rods. If your setup is gonna be less than 500whp, Eagle rods should be just fine.
I have heard of eagles failing in the 700hp range. Also, I have a set in a n/a H22 with type S pistons. I have revved it to 8500 with no problems. Hard to beat them at the price they go for IMHO...
I have some crower I beams on the way. I always thought the H-beam design was weaker.
http://www.grapeaperacing.com/GrapeA...h/rodtypes.cfm
H-beams are for High HP low rpm....
[Modified by satan_srv, 9:37 PM 3/2/2003]
Since I deal with Eagle I might be able to shed some light. The Eagle rods are tested as someone said to 600 hp. I have seen them go as high as 700 hp. I feel you can easily go 650 no prob, and on 20 psi they will work. I"ve got Eagle crank and rods in my bro's 7 sec. Mullis dragster with 2 full seasons on them and not a problem yet. I'd go with Eagle as far as your block is concerned if you need some prices let me know. I can get whole rotating assemblies, or just rods, etc. Good luck on your project.
and
and
