Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Need input on RWD handling characteristics with 1.5 or a 2way LSD
Old Feb 27, 2003 | 11:02 AM
John's Avatar
New User
Default Need input on RWD handling characteristics with 1.5 or a 2way LSD
Yes, I know this is a Honda board, but I figured some of your road racers would be able to provide me with some input...
Come April, ATS will have a carbon LSD ( http://www.a-t-s-usa.com/ats-products/lsd-carbon.shtml ) available for my Z, and I'll be eager to swap out the OEM viscous unit (it's a true POS). I understand that a 1.5 way locks partially while the 2 way clutch-type locks fully under braking. With a 2 way, will my car be more prone to drifting? I'd like to get more rotation from the rear end, but I don't want to have a really loose tail.
Your advice is appreciated. Thanks in advance.
Old Feb 27, 2003 | 12:08 PM
RR98ITR's Avatar
Default Re: Need input on RWD handling characteristics with 1.5 or a 2way LSD (DunReit)
You want minimal lockup when unpowered - else you'll have a tendency to push on corner entry and you'll have to resort to pitching the car.
Everything I've read says that until you're putting down power an open diff car outperforms any kind of lsd.
Everybody's 1.5 way has a minimal decel ramp angle for mechanical reliability reasons.
Here's a nice tuning guide: http://www.icpcitation.com/variloc.htm
Scott, who understands that viscous lsd's aren't any good unless they're electronically controlled...
Old Feb 27, 2003 | 03:08 PM
John's Avatar
New User
Default Re: Need input on RWD handling characteristics with 1.5 or a 2way LSD (RR98ITR)
Wow, that's an intensive read. So intensive, that I'm truly having difficult understanding it. If someone is able to put it in more laymen's terms? to the person who can decipher it...
Old Feb 27, 2003 | 03:28 PM
solo-x's Avatar
which part don't you understand?
thanks for the link scott, yet another one added to the favorites list.
nate-who understands but sucks royally at explaining.
Old Feb 27, 2003 | 05:35 PM
WRXRacer111's Avatar
Subarus seem to do okay with them...
Old Feb 27, 2003 | 05:47 PM
MattD@Stoptech's Avatar
Default Re: Need input on RWD handling characteristics with 1.5 or a 2way LSD (WRXRacer111)
The Z one seems to really be the weak link between the driver and the road...at least it hampers me at times....not to mention that it would happily spin one wheel in the snow while the other one was sitting quietly on the dry road... ...i almost had to use the civic to push the Z up the driveway...
grrr...viscous = :thmub down:
Old Feb 27, 2003 | 05:58 PM
John's Avatar
New User
The inherit problem with viscous LSDs is that no power will be transferred until one wheel begins to slip. It's more of a reactive LSD than a Torsen / helical type or a clutch-type.
Old Feb 28, 2003 | 03:38 AM
MechE00's Avatar
from reading Scott's link
http://www.icpcitation.com/variloc_tuning.htm
That tuning example basically tells me the answer to whether you want more or less lock on decel depends on whether you find the car too loose on corner entry. If it ain't broke, don't fix it? If you are noticing it's too loose for your liking on entry, and you feel it's not bad driving habits, alignment, tires, etc., go with the 2, it seems.. otherwise go 1.5 (if those are the choices)? (since the viscous unit is disliked, I'm assuming it's not so effective, thus putting it's performance closer to a 1.5 than a 2?)
Heh.. like the answers to all involved questions everywhere, "It depends"..
My advice is probably worth less than you paid for it.. go with what makes sense for you.
Are there any Z boards with people whose replies will be based on something other than fashion?
Old Feb 28, 2003 | 04:39 AM
John's Avatar
New User
Default Re: Need input on RWD handling characteristics with 1.5 or a 2way LSD (MechE00)
It's difficult to procure answers from other message boards. I think I'm beginning to understand how the ramp angles work now, but what throws me off by this page is that there is only one cam with a locking ramp rather than two...
If you compare the design to the Kaaz unit, you'll see the difference in the cams:
Old Feb 28, 2003 | 04:40 AM
Evan55's Avatar
but since
" until you're putting down power an open diff car outperforms any kind of lsd"
wouldnt that be a good quality? since the locking effect is only used when needed. And with a highperformance viscous unit, they can be set to very high locking rates and almost instantaneous reaction time.
Chesus-s2k
Honda S2000
35
Jan 12, 2006 09:39 AM
braypunt
Apr 22, 2005 07:48 AM
JunIntegra
Aug 8, 2003 08:03 AM
hkboy100
Mar 15, 2002 05:44 AM
