Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What's the correct offset for 15x6.5" wheels and 205/50x15" Azenis?
Old Feb 27, 2003 | 10:32 AM
CivicSiRacer's Avatar
Default What's the correct offset for 15x6.5" wheels and 205/50x15" Azenis?
I know 15x7" 45mm offset rubs the rear upper control arm on a 99-00 Civic Si. And I know the stock offset is 15x6" 45mm offset.
Would 15x6.5" 40mm offset and 205/50x15" Azenis be ok?
Thanks guys!
Mike
Old Feb 27, 2003 | 10:41 AM
Todd Reid's Avatar
Default Re: What's the correct offset for 15x6.5" wheels and 205/50x15" Azenis? (CivicSiRacer)
95 Civic hatch w/15"x6.5" Rota wheels & Kumho V700s; 38 offset working fine; no rubbing whatsoever.
hope that helps
Old Feb 27, 2003 | 10:44 AM
ryan12321's Avatar
i have 40 offset rota subzeros on my 00 si. When i was still running the azenis i would rub on the fenders but i roled them and no more problems.
edit: The rubbing occured when i still had eibach sportlines which the top of the tire rested right at the fenders. I now have GC with the same rates as you and about 3/4" higher so i'm not sure if i would have had any rubbing at all.
[Modified by ryan12321, 2:46 PM 2/27/2003]
Old Feb 27, 2003 | 11:20 AM
Geezer's Avatar
I'm running 15x7 with 40mm offset and the 205/50/15 azenis and have no problem with either the control arms or fenders. 350f/400r springs with fenders about a finger width above the tires.
Old Feb 27, 2003 | 01:23 PM
Default Re: What's the correct offset for 15x6.5" wheels and 205/50x15" Azenis? (Geezer)
Thanks guys. So it looks like my newer wheels will be 3-4lbs lighter And $50-75 cheaper.
[Modified by CivicSiRacer, 5:24 PM 2/27/2003]
Old Feb 27, 2003 | 01:33 PM
ryan12321's Avatar
want to give me your old 15x7" wheels?
Old Feb 27, 2003 | 02:45 PM
tilt's Avatar
15x6.5 +40mm /w azenis, pro-kits 1.3" drop, no rubbing
Old Feb 27, 2003 | 02:51 PM
solo-x's Avatar
Default Re: What's the correct offset for 15x6.5" wheels and 205/50x15" Azenis? (tilt)
+38mm on a 5th gen. really low, no rubbing.
nate
Old Feb 27, 2003 | 06:42 PM
Default Re: What's the correct offset for 15x6.5" wheels and 205/50x15" Azenis? (ryan12321)
No but I'm selling my 16x7.5" wheels with Kumho 712s 215/40x16" tires with lots of tread left Asking $800.
Old Feb 27, 2003 | 10:19 PM
A D NOH's Avatar
I really don't know
Community Builder
and these lighter weight, cheaper wheels will be_____???
Old Feb 28, 2003 | 05:21 AM
Default Re: What's the correct offset for 15x6.5" wheels and 205/50x15" Azenis? (TypeOne Enjoy It)
It's a secret. I can give you one hint. They used to be my sponsor
diewX3
Apr 22, 2005 07:31 AM
speedehatch
Sep 29, 2004 12:22 PM
^jefs0ng
Jan 1, 2004 07:17 PM
whitemike1644
Jun 13, 2003 04:38 AM
magic hat #9
Mar 8, 2003 04:33 PM
