power steering ripped out ??????????
Old Feb 27, 2003 | 09:21 AM
SebAyatollah's Avatar
Default power steering ripped out ??????????
when the mechanic did my swap on my 93 hatch ... he said that the power steering wouldnt fit so he disconnected it .... i just went for a test drive and that **** is so tight to turn is like you have to use so much forced to turn the wheel cause is really stiff .now this is the question that i have .have any of you guys done this . i mean ripped out the powersteering and rode on it manual but using the power steering rack ????? cause im thinking of going to the junk yard and getting a manual rack and swaping it ......also i have a strut bar on s i know that makes it a lil harder to manuver also ... do any of you guys think i should go get a manual rack or keep the power rack running it manual ntill i get used to it ????
thanks
seb
Old Feb 27, 2003 | 09:25 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: power steering ripped out ?????????? (SebAyatollah)
um...it's not that hard to turn...lol.
I ripped out my pump and lines, and just removed some fluid and blocked the lines out of the rack. It's really easy to turn, better ratio, better road feel, and no parasitic drag on the crank
EkREV's Avatar
New User
if you are not going to reconnect the power steering or you have no use for it, then i would buy a manual rack. i am driving my car that originally came w/ power steering and i yanked it out when i did my swap...and i have to use force to turn the steering wheel. i am going to reconnect the power steering later.
Old Feb 27, 2003 | 09:28 AM
Default Re: power steering ripped out ?????????? (Emerica)
do you have a strut bar ??????
Old Feb 27, 2003 | 09:29 AM
EkREV's Avatar
New User
yes.
Old Feb 27, 2003 | 09:31 AM
Default Re: power steering ripped out ?????????? (EkREV)
maybe is just that im used to driving it with power steering so it seems a lil stiffer ,, i might give a a try for a few months so maybe i get used to it .
i also got no AC now
Old Feb 27, 2003 | 09:46 AM
EkREV's Avatar
New User
i got used to driving w/o the power steering. it is a little hard to make u turns and sudden turns though...i ain't complaining. my biceps are getting a work out.
Old Feb 27, 2003 | 09:52 AM
lol true it is going to be a work out ... another uncorfortable feeling i noticed that i have to get used to is the short shifter ... the throw feels like i aint even shifting man .. but is supposssed to be more acurate for racing so ill givve it a try
Old Feb 27, 2003 | 09:54 AM
TurboBumblBee's Avatar
what kind of swap did you get? only problem ive ever heard about not using the a/c and p/s after a swap is an h22 if you did swap a b series motor into your car your mechanic didnt know much and he could have got it work. ill have a 95 civic ex w/ a gsr motor w/ power steering, and air conditioning
Old Feb 27, 2003 | 10:03 AM
Default Re: power steering ripped out ?????????? (Hybrid95CivicEX)
b 18 block b 16 head into a 93 dx hatch
Old Feb 27, 2003 | 04:09 PM
w/ that swap there is no reason why power steering and ac cant be used.. there is plenty of room for them to both clear w/ no problems
gotenz90640
Mar 19, 2016 03:57 PM
mikej94civex
14
Feb 12, 2010 06:31 AM
redboy183
10
Apr 4, 2008 08:36 PM
redboy183
Dec 18, 2007 08:11 PM
a11mtrhatch
Dec 24, 2004 07:25 AM
