balancing redrilled rotors
i have all my parts now for my lude vtec rotors and accord v6 calipers and i just need to get the rotors redrilled to 4by100 but i was wondering if i need to have them balanced after that or is it no big deal?
thanks
jesse
thanks
jesse
I got a machine shop to redrill my rotors with the same upgarde. But they did a hack job at it and it doesn't look that great. However, when i was researching about this upgrade, I was told that you can use a hand drill and drill it out yourself as the rotor is centered onto the rotor vis the hub and not the studs. I have yet installed my kit because it's winter and the car is in storage.
Don't forget, you will have to shave i think 3mm to 5mm off the caliper bracket to achieve even pad wear.
