HOW TO: Install Energy Suspension Motor Mount Inserts (pics)
Old Feb 27, 2003 | 12:17 AM
4bidden's Avatar
Default HOW TO: Install Energy Suspension Motor Mount Inserts (pics)
This was done on a 4gen, but the 5gen is basically the same. This was a joint effort between 92lude and myself. The install was done on his car. Enjoy!
http://members.***.net/4bidden/mount_install/
Old Feb 27, 2003 | 12:45 AM
ophdehEEzY
Guest
Posts: n/a
Default Re: HOW TO: Install Energy Suspension Motor Mount Inserts (4bidden)
sorry for my newbieness but what pros do you get when installing aftermarket motormounts over stock ones?
Old Feb 27, 2003 | 12:55 AM
4bidden's Avatar
Default Re: HOW TO: Install Energy Suspension Motor Mount Inserts (ophdeheezy)
Pros: Better transfer of power, reduced wheel hop, cleaner shifts
Cons: Vibration
[Modified by 4bidden, 9:55 AM 2/27/2003]
Old Feb 27, 2003 | 01:57 AM
ALTERED4's Avatar
glad to see my joints, extension, and breaker bar worked
Old Feb 27, 2003 | 04:23 AM
Finest's Avatar
Default Re: HOW TO: Install Energy Suspension Motor Mount Inserts (ALTERED4)
I have the same inserts in my 4G and when I shift to 2nd really hard, it feels like the dash is going to rip off the firewall.
ES mounts + 6 puck clutch + 555R = like Whoa!
And yes, you will get more vibration inside the cabin. I swear I discover all kinds of new rattles everyday.
Old Feb 27, 2003 | 05:03 AM
BoostedH23a1's Avatar
Default Re: HOW TO: Install Energy Suspension Motor Mount Inserts (98CTRCoupe)
i had them like 3 years now.. i cant even notice the vibration.. i know its still there though.. cams+low idle+ inserts = free vibrating car
Old Feb 27, 2003 | 07:36 AM
Daemione's Avatar
Default Re: HOW TO: Install Energy Suspension Motor Mount Inserts (BoostedH23a1)
Good writeup . . . . bookmarked.
Old Feb 27, 2003 | 09:47 AM
4bidden's Avatar
Default Re: HOW TO: Install Energy Suspension Motor Mount Inserts (Daemione)
Thanks!
Old Feb 27, 2003 | 10:59 AM
SpdFrk's Avatar
Very good write up
Quesion- I want to get the master set for my 00 lude but energy suspension only offers it for the 92-96 preludes. Can i use the master set for the 92-96 ludes for my 00 lude??
Also can anyone explain what the Manual Transmission Shifter Stabilize does?? Do they make it for preludes?
[Modified by SpdFrk, 8:04 PM 2/27/2003]
Old Feb 27, 2003 | 02:59 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: HOW TO: Install Energy Suspension Motor Mount Inserts (SpdFrk)
good write up
Old Feb 27, 2003 | 03:03 PM
4bidden's Avatar
Default Re: HOW TO: Install Energy Suspension Motor Mount Inserts (PreIudeSI)
Thanks guys.
Old Feb 27, 2003 | 05:37 PM
LoudAccord's Avatar
good job, and thanks for sharing the info
Old Feb 27, 2003 | 07:08 PM
Que_Lude's Avatar
Nice write up....... total time estimate for this mod?
Old Mar 2, 2003 | 01:21 AM
4bidden's Avatar
Default Re: HOW TO: Install Energy Suspension Motor Mount Inserts (Que_Lude)
We took our time, not rushing on anything. If you worked all the way through, I'd estimate about an hour and a half with hand tools.
Old Mar 2, 2003 | 02:21 AM
ALTERED4's Avatar
yet the first time we did the mounts, it took us and hour and a half to put ONE rear mount bolt back on the car ...
for you guys that will be installing the mount inserts yourself, save yourself the headache and trim the edges off the rear insert as derscribed in the write-up...
[Modified by ALTERED4, 4:23 AM 3/2/2003]
TypeRuz
May 20, 2004 05:55 PM
Phat_GSR
Oct 9, 2002 05:07 PM
comptechgsr
Jun 14, 2002 03:22 PM
DroppedTegra
Jan 6, 2002 10:30 AM
