Did you remove the rear inner fender trim?
Old Feb 26, 2003 | 08:15 AM
hooptie157's Avatar
Default Did you remove the rear inner fender trim?
Well I've been told many times to remove my rear inner fender trim because water can get trapped inside and cause rust SO today I did. Upon removing them alot of dust kinda just feel out and the paint underneath was looking kinda white in some spots not yellow. I just wanna see how many other owns are removing this peice also.
[Modified by hooptie157, 12:16 PM 2/26/2003]
Old Feb 26, 2003 | 08:17 AM
io_burn's Avatar
New User
Default Re: Did you remove the rear inner fender trim? (hooptie157)
I left mine the way it is, but one time when I went to turtlewax the kid who dried my car warned me about that. Is there any reason to NOT take all the inner fender trims off?
Old Feb 26, 2003 | 08:20 AM
RTW DC2R's Avatar
Default Re: Did you remove the rear inner fender trim? (io_burn)
mine didnt have the trim when I got it, so I put some on. the fact water can get trapped in there and rust the fender is true and common. my DX is fugged from that sheeyit.
Old Feb 26, 2003 | 08:21 AM
io_burn's Avatar
New User
Default Re: Did you remove the rear inner fender trim? (RTW DC2)
The question is, would it be a better idea to take them off entirely, or try to seal them in some way?
Old Feb 26, 2003 | 08:24 AM
DarthLuder's Avatar
New User
Bye the time it Rust. Its bye bye ITR.
Old Feb 26, 2003 | 08:26 AM
hooptie157's Avatar
Default Re: Did you remove the rear inner fender trim? (ITR GURU)
have you checked underneath it recently?? You should its kinda scary
Old Feb 26, 2003 | 08:29 AM
io_burn's Avatar
New User
Hmm... I'm going to check mine the next time it's less than 32 degrees outside. Is there ANY reason to leave the things on?
Old Feb 26, 2003 | 08:30 AM
Larkin W.'s Avatar
Its nasty inside of the fenderwell trim. I took mine off when I bought the ITR.
Old Feb 26, 2003 | 08:32 AM
RTW DC2R's Avatar
Im gonna take mine off now since ive seen what it did to my DX.
Old Feb 26, 2003 | 08:33 AM
Variance's Avatar
Default Re: Did you remove the rear inner fender trim? (EbboyPSi)
I did the same, not an ITR. But I had it.
Curious as to the original function of this piece? Somone mentioned it was to protect the paint from rock chips etc...?
Old Feb 26, 2003 | 08:44 AM
98type_r's Avatar
New User
Default Re: Did you remove the rear inner fender trim? (Variance)
i haven't, but maybe i should after reading this thread.
Old Feb 26, 2003 | 08:49 AM
Willard's Avatar
I removed it... cleaned under it... and put it back on.
Old Feb 26, 2003 | 08:52 AM
Larkin W.'s Avatar
Default Re: Did you remove the rear inner fender trim? (Willard)
When I had the Si, I removed it and used it as a guard in the hole that the AEM CAI goes through because that hole likes to saw through CAI's.
[Modified by EbboyPSi, 11:53 AM 2/26/2003]
Old Feb 26, 2003 | 09:25 AM
Eva01's Avatar
I think I will do that this weekend.
Old Feb 26, 2003 | 09:51 AM
Tweakmeister's Avatar
Default Re: Did you remove the rear inner fender trim? (Eva01)
I'll say it again...
http://www.hogens.com/car/default.ph...ning/index.php
Old Feb 26, 2003 | 09:53 AM
io_burn's Avatar
New User
Default Re: Did you remove the rear inner fender trim? (Tweakmeister)
Wouldn't a better solution to taking it off entirely be to drill some holes in it or something so that the water can drain out? That way you get protection from rocks, and you don't trap water?
Old Feb 26, 2003 | 09:57 AM
Edwin's Avatar
If you really want it on there, remove the innner fender trim once and a while to clean it off.
Old Feb 26, 2003 | 10:03 AM
RTW DC2R's Avatar
i think water would still find a way under the trim.
Old Feb 26, 2003 | 10:59 AM
You'd be suprised at how much "crap" gets deposited up on the inside of the lip.
Having taken mine off, the water now just runs out, and when I clean my car (once a week) I get out all the deposited stuff up there.
Old Feb 27, 2003 | 01:05 PM
PupaScoopa's Avatar
I rode in an EG hatch with the liners removed. The debris kicked up from the tires make it noisy over dusty roads. Maybe spray it with some rubberized undercoating to keep it quiet.
Old Feb 27, 2003 | 01:10 PM
Understeer's Avatar
Default Re: Did you remove the rear inner fender trim? (PupaScoopa)
Took mine off permanetely. I had handfuls of mud and sand when I wash it out with my hands.
I checked the RSX and they don't have the rear fenderall trim.
Most cars I have seen don't have it, so I'm keeping mine off.
I see no harm with it off.
Old Feb 27, 2003 | 01:27 PM
Phoenix_ITR's Avatar
Default Re: Did you remove the rear inner fender trim? (Understeer)
just to clarify, are we talking about the rubber lining on the lip in the rear wheel well?
also, my car will never leave the southwest -- IE: no snow, no salt. do you think i'm still at risk for rust to start forming?
-tony
Old Feb 27, 2003 | 02:34 PM
RTW DC2R's Avatar
Default Re: Did you remove the rear inner fender trim? (delinquent)
-tony
yes, you dont need snow or salt for rust to form. all it takes is water and metal(i think the metal has to have iron in it for it to rust though, but im not a science major so im not sure)
Old Feb 27, 2003 | 02:38 PM
vtec.dc2's Avatar
yes, remove that.
all latest honda models don't have fenderwell trim.
Old Feb 27, 2003 | 04:08 PM
Tommy_Gunns's Avatar
Default Re: Did you remove the rear inner fender trim? (vtec.dc2)
I left it on. Just clean every once in a while and spray some water deterent in there.
