Can you calculate my new compression ratio after getting my head milled?
Old Feb 26, 2003 | 07:37 AM
Hybrid's Avatar
Default Can you calculate my new compression ratio after getting my head milled?
I had 8.5:1 compression. I had my head milled with 0.010 removed.
Can any one estimate what my new compression is?
Old Feb 26, 2003 | 09:25 AM
The_Head's Avatar
Default Re: Can you calculate my new compression ratio after getting my head milled? (Hybrid)
Which motor is it? That is important. That milling should bump comprssion up 0.1-0.2 points
Old Feb 26, 2003 | 10:31 AM
Hybrid's Avatar
Default Re: Can you calculate my new compression ratio after getting my head milled? (xThexHeadx)
Z6 block with Y8 head, my Arias pistons give me 8.5:1 compression ratio with that head/block combo.
So with the head milled 0.010 over, then my final compression is.....................................?
Old Feb 27, 2003 | 04:10 AM
Hybrid's Avatar
bump
Old Feb 27, 2003 | 04:13 AM
turbodav's Avatar
about 8.7:1
Old Feb 27, 2003 | 11:53 AM
AzG35's Avatar
Default Re: Can you calculate my new compression ratio after getting my head milled? (turbodav)
.010 is equivalent to about .2-.3 points of compression. So you are at about 8.8:1
Old Feb 27, 2003 | 04:33 PM
mattcxb18's Avatar
Default Re: Can you calculate my new compression ratio after getting my head milled? (AzSi22)
http://www.c-speedracing.com/howto/c...c/compcalc.php
Good Site
Old Feb 27, 2003 | 05:51 PM
slomofo's Avatar
GDD Member
Just curious, not trying to start anything. Why did you get low CR pistons and then get your head milled to raise the compression?
Old Feb 28, 2003 | 08:29 AM
AzG35's Avatar
Default Re: Can you calculate my new compression ratio after getting my head milled? (slomofo)
Probably turboing the motor and needed the head milled due to warpage?
Old Feb 28, 2003 | 11:59 AM
Hybrid's Avatar
I blew the damn motor and damaged the head. Put it back together, realized this afterwords. Its winter here, so I have the car in peices. The head is not ready to go back on.
mike93eh2
Feb 11, 2009 08:09 PM
candy eg
Jun 28, 2006 01:38 PM
Techna600f4i
Jun 19, 2006 11:49 PM
flatty
Jan 25, 2005 10:16 PM
Mentat Ghola
14
May 11, 2004 02:35 PM
