egr blockoff
Old Feb 26, 2003 | 05:58 AM
philipkrotch's Avatar
Default egr blockoff
i blocked off my egr and plugged the vacuum line going to it and my idle was going craaazy. would it be due to me not sealing it well enough or dos it just **** up the car.lol.
Old Feb 26, 2003 | 07:23 AM
twkdCD595's Avatar
Default Re: egr blockoff (philipkrotch)
Well it is going to throw a cel and yes idle like dog ****...
Old Feb 26, 2003 | 07:28 AM
boonacka's Avatar
Default Re: egr blockoff (twkdCD595)
keep the connector plugged in so that it wont throw a CEL
Old Feb 26, 2003 | 08:37 AM
GZERO's Avatar
Default Re: egr blockoff (boonacka)
so there is no way you can take the EGR off our cars?
Old Feb 26, 2003 | 08:40 AM
niedejb's Avatar
Default Re: egr blockoff (GZERO)
Its been done.
I'm simply putting a piece under the inlet exhaust distributor to each runner to block the gases. Everything will act like its suppossed to, but no exhaust will flow into that dist plate.
Old Feb 26, 2003 | 08:42 AM
GZERO's Avatar
Default Re: egr blockoff (niedejb)
and you will get a cel? or there is a way to cheat the ECU to think it still has the egr working properly?
Old Feb 26, 2003 | 08:52 AM
niedejb's Avatar
The only CELs if for no lift on the EGRvalve or vac solenoid malfuction, both of these will stay functional.
Most EGR cels come from the passage getting clogged and the lift on the EGR valve is blocked.
Old Feb 26, 2003 | 09:22 AM
Stew Pidasso's Avatar
https://honda-tech.com/zerothread?id=287553
https://honda-tech.com/zerothread?id=307945
Old Feb 26, 2003 | 09:37 AM
Default Re: egr blockoff (Stew Pidasso)
ya but im OBDI because im in a 4th gen...would i still trip a light?
Veggie Man
Nov 1, 2012 02:49 AM
92bseries
Dec 7, 2011 12:59 PM
shutta
May 2, 2007 01:38 PM
DarkBB4
Nov 8, 2004 05:08 PM
B00ST2nR
Apr 18, 2003 04:03 PM
