how hard to swap in a 1st gen b16a? really?
I've got up to 2g's to spend. My current engine d15b2 needs pistons rings. I can install intakes and headers, never done full exhaust before.
Plan to buy the swap from hmotorsonline or Import Auto Salvage(1150) plus 200 for shipping
HCP engine mounts(250)
and wiring harness(150)
How hard will this swap be?
If its too hard I might just get a zc with mods.
If know places with better prices let me know.
well if you are going to do the swap yourself, then you are going to have to ask yourself a few questions. 1. Do you have good knowledge of both motors? 2.Do you have other transportation? 3. Do you have the necessary tools? If the answer is no to any then if you age going to do a swap then it better be a ZC. you will save your self a lot of trouble and heartache...but then again there is just something about hearing a b16 scream that i cant get enough of.
On my site I have a parts list with prices, and a complete how to section on the swap. Check it out. Its in the sig. Ryan
the hardest part is the wiring. and if your gettin a zc. it's almost as much wiring as the b16.
If you have any doubt that you can't take on this project, take your car to a shop.
Good luck.
[Modified by madeiniraq, 12:45 AM 2/26/2003]
Good luck.
depends, OBD1 dizzy's are easier to find than an OBD0 one.... OBD1 ECU's kick ***. OBD2 people switch to OBD1 and alot of OBD0 people switch to OBD1 so there are tons of programs for OBD1 engines.
well u should tell HMOTORSONLINE TO MATCH PASSWORDJDM.com price for the b16a1. PASSWORDJDM.com B16a1 is cheaper then HMotorsonline. I personally drove all the way down to LA and picked up my b16a from Hmotorsonline. and the engine was good. i ran 14.8 bone stock no mods done. wit no tone up r anything.
Its not that hard to swap a b16 in to your civic. The hardest part is like they said , the wiring. But hasport has the diagram so you could exactly match everywire.
if yours is a dx go here
http://www.hasport.com/Tech/Wring/Dx...r%20wiring.PDF
if its an si then go here
http://www.hasport.com/Tech/Wring/88...20to%20B16.PDF
either way hasort has lots of worthy info.
the only advantage of a zc to my knowledge is that there is not horsepower gap when the vtec kicks in if your turbo. Otherwise get the b16 first generation with a cable tranny. Y1 lsd preferably. Hmotorsonline.com is where I got my engine and i paid extra 300 for my lsd tranny. So far I have had no problems and that was 16000 miles ago. as for obd0, or obd1, or obd2, i have no idea which is better but mine is a first gen b16 sojust my 2cents
I'm going to convert my B16 into OBD1. I'm looking to engage vtec between 4k and 5k, which ECU should I go with?? I'm looking into a virgin, stock ecu.
here are my reccomendations, get yourself a SI wire harness if you have a dx, Have a 5 foot pipe and a large breakerbar/ratchet/ high torqe impact gun to remove axle nuts (i needed the 5 foot bar the first time i removed them), get hasport mounts, subharness, shiftlinkages, Raxles axles, new oil and water pumps (reccomended not nessesary), you'll definately need a cherry picker, i know i'm forgetting some stuff *poof*
Si Harness w/ injector resistor 60$ tops, hasport sub harness 75, shift linkages 200,
[Modified by Nismo240sx1, 2:56 AM 2/28/2003]
if you can solder and run a wire from the ecu to sensors/injectors.. just make the harness. MPFI and VTEC
i paid 75 for my first one.. and have built 2. it's easy stuff.
jorkee
54
Jan 25, 2008 08:08 AM
