Cams
Old Feb 25, 2003 | 05:28 PM
abeaujuin's Avatar
Default Cams
Are Cams worth putting on a 95 Accord EX VTEC? Will they give pull off power?
Old Feb 25, 2003 | 05:30 PM
niedejb's Avatar
Default Re: Cams (abeaujuin)
A second one wouldnt hurt.
Old Feb 26, 2003 | 04:03 AM
Stew Pidasso's Avatar
Default Re: Cams (niedejb)
{snicker}
Old Feb 26, 2003 | 05:04 AM
carolinaACCORD's Avatar
Default Re: Cams (Stew Pidasso)
just a little info, you may or may not know but that engine is a single cam. but anyway, you can have your cam regrinded, you'll just need to send in your core.
imo, you need to do some more mods to, and not just the camshaft.
niedejb, that was very, very funny.bwahahahahaha!
Old Feb 26, 2003 | 05:32 AM
97F22B2's Avatar
Default Re: Cams (carolinaACCORD)
im going with a Web cam in a 97 non vtec, as large as i can go with the Vtec valves, stock springs and fuel. But my pewter will need remapped and all that goodie stuff.
Old Feb 26, 2003 | 07:29 AM
twkdCD595's Avatar
Default Re: Cams (97F22B2)
Only regrind are available thus far for the f22... but it would make a good bit of power to have the cam reground with more lift and what not.
As others said you would need some other mods to help un cork the intake/ exhaust to really make the cam beneficial.
Old Feb 26, 2003 | 08:21 AM
Nick M's Avatar
you arent going to be able to go very big with a stock valvetrain
Old Feb 26, 2003 | 11:15 AM
RABBIT9's Avatar
Default Re: Cams (Nick M)
I'm also going with a regrind from WEB. Waiting on the head to get back from Port Flow. Tom recommended swapping the valvetrain, so were going with Ferrea.
Old Feb 26, 2003 | 12:01 PM
philipkrotch's Avatar
Default Re: Cams (RABBIT9)
ya well i have hollow cams from APC! wHOOOOOOOOOOOO!!
Old Feb 26, 2003 | 12:31 PM
Crono139's Avatar
Default Re: Cams (philipkrotch)
Ah, the dreaded APC. At my last stop to PepBoys, I saw some APC coilovers for sale. The box was opened, just instructions, and the coilovers were in the box. No padding, nothing. I hate APC regardless.
Old Feb 27, 2003 | 04:14 AM
Default Re: Cams (Crono139)
Did the instructions say:
Step 1: Take off factory springs
Step 2: Replace with APC coilover system
Step 3: Apply windshield banner with APC logo
Old Feb 27, 2003 | 05:14 AM
97accordex's Avatar
I have often wondered about "regrinds". When a shop does a "regrind" dont they have to add material to the cam lobes then grind it back down?
When you talk about increasing lift, does this refer to duration only or the actual distance of the valve from the seat?
Old Feb 27, 2003 | 11:04 AM
One2chi's Avatar
Default Re: Cams (97accordex)
what he said.... i wanna knwo too
Old Feb 27, 2003 | 01:37 PM
niedejb's Avatar
Default Re: Cams (One2chi)
I'm not sure on the adding the material, but most cams I've seen are carburized (case hardened). These "cases" are only a mm or so deep and once ground away leave the softer core steel.
Dont know if the OEM cams are carburized or not. They could be through hardened (all the way through) and this wouldnt be an issue.
roddy9
Jan 8, 2008 08:54 PM
DrewQ1
Mar 7, 2004 05:03 PM
TRuST
Jun 3, 2003 01:15 PM
Mr.FBR
Nov 26, 2001 05:05 AM
