Converting a JDM CTR to Left hand drive.
Rather then importing all the parts and creating a CTR from a USDM chassis, wouldnt it be easier to just import a real CTR from Japan and convert it to Left Hand drive??
My question is, how much is involved in changing a right hand drive car to left? Do you just need a new dash??? What parts are needed for this conversion?
i think you need to CUT off that front clip of the usdm chassiss, and THEN get the front JDM end welded on. and then hook everything up, thats why you buy a whole jdm front clip with the motor, cause youll be using everything on that clip such as the rhd wire harness, the throttle cable and the whole under dash wiring on the clip.
good luck
good luck
good luck
good luck
and yeah what a waste. B16B is a USDM 96+ hatch is cheaper. but I would rather go B18C5 in a USDM hatch.
good luck
no need to cut the 'front clip off'. just remove and replace the firewall. easy as that.
good luck
what are you talking about? its a lot safer than cutting off your front end to tack on another. how do you think the factory puts the car together? nothing wrong with a firewall swap.
If it's worth it to ya, you can send the car to an EPA company and have it converted to meet the US safety and emission standards. Maybe it would take like a year or so and extra cash, but it sounds good to have it legal and drive it as much as you want rather than only allowed to drive 2500 miles a year in "show car" mode.
killerpenguin21
Jul 6, 2006 09:49 PM
TuCKiNaLL4s
Jun 7, 2004 07:46 PM
TuCKiNaLL4s
May 12, 2004 08:42 AM
either keep it RHD or use a US chassis and build a CTR
