Anyone ever do a Auto to Manual conversion on a 91 dx????
Old Feb 25, 2003 | 11:52 AM
RuthlessEF-9's Avatar
Default Anyone ever do a Auto to Manual conversion on a 91 dx????
I only ask cause that when i went to put on my shift linkage i noticed that there were no tapped holes for the 10mm bolts that hold up the shift linkage
i really need help
thanks guys
Old Feb 25, 2003 | 02:19 PM
SEA Hag's Avatar
Default Re: Anyone ever do a Auto to Manual conversion on a 91 dx???? (D16z6turbs)
I just drilled one hole, using the shifter bushing as a template so that it would line up correctly. Then I used a locking nut on the bolt. It probably isnt lined up dead on but it works. The 2nd gen integra and d series shift linkage bushings are the same by the way.
Old Feb 25, 2003 | 03:19 PM
chad174's Avatar
Default Re: Anyone ever do a Auto to Manual conversion on a 91 dx???? (SEA Hag)
i did it on an 89 dx. i held the mount plate thing from an integra over the shifter area of the crx, lines up where the bolt holes would be, and just held it there and drilled it. works fine for me. i'm using the hcp adjustable shift linkage and it feels pretty good. good luck. email me if you need more help with the auto/manual swap.
Old Feb 25, 2003 | 03:54 PM
Speed PHreak's Avatar
Have fun with no power steering......oh i've did that swap to. It's a pain in the ***. Also the pedals are a bitch to swap out to.
Old Feb 25, 2003 | 04:57 PM
bodymodgrl's Avatar
Default Re: Anyone ever do a Auto to Manual conversion on a 91 dx???? (Speed PHreak)
Having no power steering really isn't that bad! When you are sitting at a complete standstill it can be a pain, but nothing major.
Old Feb 25, 2003 | 05:20 PM
Default Re: Anyone ever do a Auto to Manual conversion on a 91 dx???? (bodymodgrl)
Note: I'm not talking about just not having power steering at all. I'm talking about having a p/s rack without the power assist from the p/s pump. Which is a noticable difference. Been there done that, since all DX's with auto trannies come with power steering.
Old Feb 26, 2003 | 02:26 AM
SEA Hag's Avatar
If you let the rack breathe by using a small resevoir to connect the power steering hoses and keep it filled with fluid, you wont have trouble parking.
Old Feb 26, 2003 | 04:16 AM
CWBETB's Avatar
Why couldnt he just keep the power steering hooked up? My Civic was a auto DX and Im still using power steering?
Old Feb 26, 2003 | 08:47 AM
Default Re: Anyone ever do a Auto to Manual conversion on a 91 dx???? (CWBETB)
the rack is gone anyway i plan on chaning it out for a non power steering rack
i really don't like the fact you get little feedback from power steering
Old Feb 26, 2003 | 12:45 PM
chad174's Avatar
well, you're wrong about all dx auto's having power steering. because my dx auto sure as hell doesn't. and no, the ps isn't just gone out, its jut not there.
Old Feb 26, 2003 | 02:23 PM
wannab20hatch's Avatar
Your wrong from what ive seen only 90-91's came with power steering. My 91 dx has it but my friends 88 dx doesnt. And both were converted to manual.
Old Feb 26, 2003 | 03:25 PM
OldSchoolHatch's Avatar
Default Re: Anyone ever do a Auto to Manual conversion on a 91 dx???? (wannab20hatch)
I didn't realize so many people change theirs cars from auto to manual. I thought it was extremely hard to do right, and usually not worth the effort. Guess I was wrong...
Old Feb 26, 2003 | 04:46 PM
Vinceg99's Avatar
What I am going to be doing when I do my swap is taking that section out of the parts car and welding it into my car. There are only a few spot welds holding it on and if you get a spot weld cutter they pop right off. I did it the longer way though since I was scrapping my parts car I went and took the sawzall and went and cut out the whole tunnel there and will be removing the section seperately. I dont know if they would be the same for the CRX and the Civic but I have another parts car (CRX) and I would be willing to cut that piece out for you and send it to you for a small price. Let me know.
Old Feb 27, 2003 | 10:44 AM
Didn't know that, thanks for the info
Old Feb 27, 2003 | 11:15 AM
RCautoworks's Avatar
Default Re: Anyone ever do a Auto to Manual conversion on a 91 dx???? (Vinceg99)
All I had to do was drill 2 holes, why would you do all that ?
Old Feb 28, 2003 | 12:54 PM
Default Re: Anyone ever do a Auto to Manual conversion on a 91 dx???? (90blackcrx)
Yeah why go through all the trouble?
Old Feb 28, 2003 | 11:29 PM
Vinceg99's Avatar
Cause then its just like factory, done right, and then I can use the inner boot cover so I dont get road noise or air into my car. And if you think its that much trouble well then you obviously never did major body work like replacing full rear quarters or replacing the door skins now thats work not taking out like 10 spot welds and then tacking it back into place.
beamer
Feb 19, 2010 01:52 AM
OldMajor
Jun 19, 2009 10:49 PM
xkrazyxjbrkerx75
Oct 19, 2008 01:27 PM
omgwtfbbqcrx
Apr 24, 2006 08:16 AM
TIRENECK
May 7, 2004 09:01 PM
