LS Swap
Old Feb 25, 2003 | 05:57 AM
EH2-LS-TURBO's Avatar
Default LS Swap
im getting a swap into my 94 hatch and i want to know how much a complete LS swap would cost. thanks
Old Feb 25, 2003 | 06:41 AM
SoulSurfer's Avatar
Default Re: LS Swap (EH2-LS-TURBO)
You can probably get one installed for $1500-2000 depending on where you are and who you take it to.
Old Feb 25, 2003 | 06:50 AM
eghonda's Avatar
Default Re: LS Swap (LSDelSol)
there is one in the classifieds for around a grand. check it out
Old Feb 25, 2003 | 07:03 AM
BackSideSA's Avatar
Default Re: LS Swap (eghonda)
got mine for 2200 installed and out the door in 6 hours
kinda high but i'm also in texas
Old Feb 25, 2003 | 07:12 AM
Jon Black's Avatar
Default Re: LS Swap (HybridHackBatch)
So have you had a chance to take it to the track and get some data yet?
Jon Black
Old Feb 25, 2003 | 07:56 AM
Patron's Avatar
$1200-1800 Tops. If you let someone install it for you, the standard rate around here is $500 for a turn key swap. If I were you, I would save that money, research a little and do the swap yourself.
Old Feb 25, 2003 | 09:03 AM
BackSideSA's Avatar
Default Re: LS Swap (ptran13)
when i ran at the track the first time i ran 15.6, which to me SUCKED *****
BUT here was the conditions ; i did no sort of prep, tires were cheap Discount tire 4 for 100 federales that were bald. car weighed in at 2500 with me in it and i onle weight 180 ( i had my baby car seat, a hydraulic jack(emergency), spare with stock jack and my skateboard.), my intake was homemade and it sat almost on top of the valve cover and the filter was so dirty. the track conditions were very poor that night. considering that mustang 5.0's with N20 were ONLY running 14.7's.
ill phil can vouch for track conditions.....he met me up there. his b16 hatch couldnt break into the 14's that night. he ran constant 15.1's and 15.2's
Old Feb 25, 2003 | 09:04 AM
BackSideSA's Avatar
i'm going again with the same setup with new tires and taking all that unnecesary **** out. new intake hopefully
Old Feb 25, 2003 | 10:44 AM
SIUL8R's Avatar
You can find usually find an LS installed for 1500-2000, I didn't do my own swap(ended up buying one with the swap already) but before I bought my car I was researching about the swap and from what i've heard its pretty simple, so you'd probly save yourself about 500 bucks jus doin it yourself
DC2AznCUddy
Jan 18, 2010 01:12 AM
djgruesome
28
Feb 18, 2005 09:36 AM
DRKSol
Sep 4, 2003 07:02 PM
