what is a "cold start" injector?
Old Feb 24, 2003 | 06:39 PM
civicracer1993's Avatar
Default what is a "cold start" injector?
what is the cold start injector. cause in my big shop manual for my civic it says if it has trouble idling good it could be a cold start injector but i dont know what this is and or how to fix it..
mike
Old Feb 24, 2003 | 07:01 PM
shawnhayes's Avatar
Default Re: what is a "cold start" injector? (civicracer1993)
mike
A cold start injector is an injector that the ECU (or other control) fires when the coolant temperature and intake temperature are very cool. It is usually upstream of the throttle body, but can be between the throttle body and intake runners. At startup, engines require a richer mixture to keep running. Mechanically injected engines pioneered the concept of a cold start injector.
I wasn't aware any Honda had a cold start injector. That's news to me. It's a standard injector. If you can find it and you can change other injectors, I'm sure you can fix this.
Shawn
[Modified by shawnhayes, 4:02 AM 2/25/2003]
preludeNApower
Apr 6, 2014 04:29 PM
HondaLude93
Aug 3, 2008 11:50 AM
bagpipe goatee
Sep 1, 2006 09:21 AM
Brolli007
Nov 18, 2002 08:48 AM
