MAPS sensor question
yeah...here is my problem i am getting the code and when i hold the gas like at a steady rpm is sputters like it isnt getting enough fuel and its not the hoses so i assume it is the wiring so i am trying to figure out if i have it wrong so i need to know what wires go to what?
Here is the problem. When he is driving it, and holds it at a certain RPM it starts sputtering, and jumps a little. And the only code hes throwing is the map sensor. He is running lean I think. So I was telling him to make a post to see which wires go to the map sensor on the map sensor. HF has like 5 map sensor wires compared to the 3 that need to go on the Z6 trottle body. We are just trying to figure out what way we can fix that MAP sensor code.
just disconect the MAP sensor plug off ur stock MAP sensor.... and plug that sensor to the Z6 TB mounted MAP sensor..... it should work jsut fine...... does for me
i think is yellow green and white...not sure..since you have an hf you map sensor is mounted to your fire wall in a black box..theres 2 plugs in the box one has a bunch of wires and the other only 3 wires...the 3 wire one is your map
[Modified by iwouldHITit, 9:14 AM 2/27/2003]
i dont have the stock one i had a z6 in there at first and so i got rid of it, then my motor blew and i am using a y8 now and the z6 manifold and it should be the same but it isnt working right i dont know what i did between the time of the motor removal to the motor drop maybe some ideas?
vtecn8ive
Jun 19, 2005 12:10 PM
