wiring ?
Ok, I have a 97 ex and will be purchasing a b16 fairly soon. I am fairly sure that it will be an OBDI engine (i know for alot of you that is not legal, but God bless SC and no emissions checks). Now, for the wiring what do i need? I am fairly sure it is not plug and play anymore as it is with the OBDII engines. Is it easier to buy a jumper from Kenji or someplace else, or just do the cutting and splicing myself. I have a decent knowlege of how to solder and make good connections, but just wondering if figuring out the pin-outs is difficult. Also, will the combination of my stock harness and the one that comes with the engine be enough to make this work?
Thanks in advance
Thanks in advance
If you want to get a B16 swap, the easiest thing to do would to get an obd2 b16 swap, then getting an obd2->obd1 jumper harness and running an obd1 ecu.
this would save much time.
