sh's with turbo
So i just got a response from greddy saying that they dont expect a kit for the sh. does anyone else have an sh with turbo, and what kind of fabrications to the kit did you have to do?
if not, i guess ill have to go NA.........
oh and i know i could have hit search but i felt like writting this just to get called stupid for not hitting search.......
that and i have visited many of the turbo posts and it doesnt seem to have anyone with an sh
i believe its 250-280whp and you lose the functionality of the ATTS....i have an SH and I plan to go turbo and am not worried about losing the ATTS..what i am worried about is blowing my motor and the fact that im having a hard time a reputable tuning shop that wont make my motor go boom because of their bad tuning...yeah you can remove the ATTS but it would cost too much...a T4 60-1 will take care of that dead weight and then some
if you need tuning on your motor, i'd love to be the one to help out. just need to drive the 3 hrs or so to syracuse. i'm in the process of building up a prelude to turbo myself but we should be able to tune your stock block to handle 8-9psi without blowing up. i would not push it past that. i recommend you go Hondata.
i cant promise that your motor will not blow but i can promise that i can tune you to your desired specs. no one will guarantee not to blow your motor!! there are too many variables.
i personally recommend a built motor then you dont have much to worry about
[Modified by GruvyTune, 6:36 PM 2/24/2003]
yes mostly non built but i have heard my fair share of built motors...its so hard to find and trust someone with tuning...oh is it true you have to have 2 different i think its fuel maps???not sure...please correct me if im wrong...one for winter..if applicable and 1 for spring/summer/fall???
Mine is SH with Turbo and is being rebuilt as we speak. You lose ATTS with any increase in torque above stock. I had to modify a few things to get the turbo kit on bit it did work out in the end.
So what are you saying, normal bolt on will make you lose the atts, cause mine still kicks in?!?!?! and what kit do you have?
does anyone have a NA sh that makes good HP and still has atts
mugenpoweredlude: your a member at po.com? can you find out for me what the NA sh are pushing?
sure no prob..but what the other guy said is not true....ill post results of what the N/A guys over at po.com are running and if they still have their ATTS active tomorrow afternoon
aight, cool. thanks man. it just sucks losing it, even though im sure you wouldnt mind if the suspension is tuned real nice. But oh well, as if the prelude wasnt heavy enough, we dont really need 80 extra lbs. so technically you could boost it moderately and keep the atts if you only have like 230-250 hp?
it depends...some say this number and others say other numbers...i gues we will find out for ourselves when and if we go turbo
as every car is different..as i concluded from all the different numbers people are telling me with the ATTS and all
One member on po.com had an SH JRSC setup running 9 psi on a GE sleeved and built motor. He was pushing about 260 whp and still had a fully functional ATTS system.
is it worth it? have you had more help there than here? not that the people here arent helpful, thanks everyone
Its $6 well spent...the knowledge i have gained from there...whoa!!..very good information especially FI..if you gonna join my id over there is:
N2oSH..just so you know
yeah yeah I know im not squeezing...i needed a sn so i just put in anything
[Modified by MugenPoweredLude, 9:37 AM 2/25/2003]
I kept my same name over there but i guess they dont officially call you a member till they recieve the 6 bucks huh? oh well, i guess ill be there in a few days then
