Question about tire fitting on certain wheel....
Old Feb 24, 2003 | 11:18 AM
blufke's Avatar
Default Question about tire fitting on certain wheel....
Would a 205/60D13 (hoosier autocrosser) be able to squeeze onto a vx wheel? What about say a steelie?
Old Feb 28, 2003 | 04:51 PM
blufke's Avatar
Default Re: Question about tire fitting on certain wheel.... (blufke)
anyone?
Old Feb 28, 2003 | 05:00 PM
Loco Honkey's Avatar
I'm going to say no, because that wheel is 5.5" wide, and the Hoosier 205's tend to be 215- 220mm wide (~8.5"). This will bow the tread of the tire, reducing your contact patch. As a general rule of thumb, you want your sidewalls as vertical as possible.
There is some tuning you can do by changing wheel widths to angle the sidewalls. Sidewalls that look like /__\ (if this doesn't make sense the __ part is the tread on the ground) will cause the tires to grip less, but will transition from static to dyncamic friction much more linearly. If the sidewalls are like |__| you'll have the most traction and the transition will be somewhat more abrupt. If they're like \__/ then the transition will be sudden and violent. The ammount of tuning you can do like this is negligable at best and the differences rendered won't be noticeable in anything other than a heavily modified (read GT5 class) cars.
Old Feb 28, 2003 | 05:50 PM
blufke's Avatar
Default Re: Question about tire fitting on certain wheel.... (Loco Honkey)
how wide are steelies? they are mounted on steelies right now.
Old Feb 28, 2003 | 08:14 PM
5.5". If I remember right, all 13" Honda wheels are 5.5" wide.
Old Mar 1, 2003 | 02:25 PM
blufke's Avatar
i know they wont grip as well as they could, but are there any damaging drawbacks to doing it? could i hurt my drivetrain or anything else putting them on the vx wheels?
Old Mar 1, 2003 | 02:27 PM
OC 335i's Avatar
Not sure about Hooisers but my Falken Azenis (205x50x15) say on the tire specifically to not mount on a 5.5" rim.
The place doing the mounting should know... If they don't, take it to a different place.
Old Mar 1, 2003 | 09:16 PM
mycivicstoo(s)low's Avatar
Default Re: Question about tire fitting on certain wheel.... (MEGA EK)
The Azenis say not to mount on a 15.5" wheel, not a 5.5" wheel.
Old Mar 1, 2003 | 09:58 PM
blufke's Avatar
Default Re: Question about tire fitting on certain wheel.... (mycivicstooslow)
cool, looks like im putting the slicks on them.
Old Mar 1, 2003 | 10:06 PM
OC 335i's Avatar
haha you're right. oops )
Old Mar 2, 2003 | 01:46 PM
blufke's Avatar
tried to get em mounted today at wallymart and they wouldnt, said the tread was too low. and i wanted to use them tonight too, crappdappy.
ITR3189
Nov 9, 2007 12:34 PM
pyrojeff
Jan 18, 2004 09:58 AM
conesmasher
Mar 8, 2003 07:30 AM
Flux
Mar 5, 2002 07:19 PM
