Spring Differences
Old Feb 24, 2003 | 10:43 AM
Blackrain's Avatar
Default Spring Differences
I'm about to buy H&R Sport springs for 96-00 SI to put on my DX (2000).
On the H&R Site they are different part numbers...
Any real difference between the 2 ??
(Si and Dx H7R SPrings)
anyone ever did this or know some kind of answer.. and what might result in installing these on my hatch ?!
Thanx !!
Old Feb 24, 2003 | 10:47 AM
Spade's Avatar
Default Re: Spring Differences (Blackrain)
Yes, the ratings.....the SI has more weight in the front (larger engine) so, it needs more "bounce"
Old Feb 24, 2003 | 10:54 AM
Blackrain's Avatar
Default Re: Spring Differences (Spade)
I see
Well what will that change on my DX ?
Feeling, handling, look(drop) ?!
I have Konis btw :D !!
Thanx for all the info... btw I called H&R to know this.. and they didn't know.. they said "Maybe the spring rate is a little different @ the front... but I am not sure @ all.. maybe its a fitting issue" so
Old Feb 24, 2003 | 11:02 AM
Spade's Avatar
Could be all 3.
I would email or call the company and ask them the difference on the springs.
Old Feb 24, 2003 | 11:15 AM
Blackrain's Avatar
I did call H&R ... they didn't know.. they thought they might not fit.. that 's all !!
In other wors.. I must know.. what does "stiffer springs" do on your car ?! (higher spring rate)
[Modified by Blackrain, 8:25 PM 2/24/2003]
Old Feb 24, 2003 | 12:35 PM
Blackrain's Avatar
Okay.. so here's what I was told..
the car will be 100% the same, but might have more aggressive performance and be stiffer... same drop, better control.. is this possible ?!
Old Feb 24, 2003 | 12:46 PM
Spade's Avatar
yup.
Old Feb 24, 2003 | 12:47 PM
PupaScoopa's Avatar
Stiffer springs aren't necessarily going to give you better performance. Your springs should be stiff enough so that your suspension never hits the bump stops. The lower you go, the stiffer the spring to control the weight of the car.
Old Feb 24, 2003 | 01:10 PM
Blackrain's Avatar
Default Re: Spring Differences (PupaScoopa)
But can it affect the amount of drop ?!
Smackin
Dec 7, 2018 11:59 AM
GnrlKll
Suspension & Brakes
Feb 1, 2013 09:13 AM
fireant
Nov 13, 2008 04:46 AM
_Cyclone_
10
Feb 8, 2005 08:33 PM
Jason C SBB
May 25, 2003 08:04 AM
