CTR pistons ? B16
Old Feb 24, 2003 | 09:35 AM
mist sITR's Avatar
Default CTR pistons ? B16
i have a 99si and am looking to get CTR pistons. when i researched it siad that standerd pistons will fit without mod. Xcept for milling the rods? what does that mean and how diff./expencive is it? also are there any rods made fo the CTR pistons i could just replace instead of milling? this is all i know so if there's any more steps or things i need to upgrade plz tell me
Old Feb 25, 2003 | 08:27 AM
mist sITR's Avatar
Default Re: CTR pistons ? B16 (mist Si)
no one can help me? i have searched?
Old Feb 25, 2003 | 08:57 AM
137's Avatar
137
there was either a topic on this last week, in tech, or this week in here, search around bud... it basically means you will have to modify the rod to fit inside of the piston as the stock b16 rods are too big for the pistons to fit w.o modification if i read the last post correctly...
no you cannot use ctr rods on b16 crank to solve problem...
you are prolly better off using usdm itr pistons as the ctr's might raise the c/r a tad more than you would want it to.
I am putting itr's in mine!!!
Old Feb 25, 2003 | 09:00 AM
Chris y0!'s Avatar
Default Re: CTR pistons ? B16 (137)
ITR pistons will lower your compression!
stock B16a is 10.2:1, add some CTR pistons and its 10.8:1 which is stock B16b compression. if you put ITR pistons in your b16a you go down to 10.1:1! yikes!
and as for milling the rods, that dude is right. the top of the rods don't fit inside the pistons so you have to shave them down.
[Modified by Spoon Hybrid, 6:07 PM 2/25/2003]
Pr0j3ctxH@tchx90
12
Jul 11, 2007 09:16 AM
Sean @ ESG
26
Jan 8, 2007 11:17 AM
Han Solo
Mar 11, 2006 12:03 PM
KoRE
Mar 3, 2003 01:04 PM
carcala
May 18, 2002 03:12 PM
