Drawback on lower (195/50/15) profile tires?
Old Feb 24, 2003 | 08:33 AM
Nuts's Avatar
Default Drawback on lower (195/50/15) profile tires?
I got an offer for a good price on T1S 195/50/15. Just wonder is there any drawback on going lower profile tires as compare to stock 195/55/15?
thanks,
CS
Old Feb 24, 2003 | 08:40 AM
Dirt's Avatar
Default Re: Drawback on lower (195/50/15) profile tires? (CS)
Contact patch should be slightly more narrow than the 195/55. I have 195/50 PZero's to go on this spring, but I am stock so traction shouldn't be an issue. How much can you get the T1-S for?
Old Feb 24, 2003 | 08:56 AM
Petah's Avatar
Default Re: Drawback on lower (BrewCityR)
Wouldn't contact patch be the same? I thought the only difference will be the rolling diameter of the wheel since the side wall will be 50% of 195 as suppose to 55% of the 195?
Old Feb 24, 2003 | 09:13 AM
vtec.dc2's Avatar
on drawback is these tires don't meet max. load capacity http://www.toyo.com/tires/tire_specsheet.cfm?id=2, now you will see few replies telling how they run 195/50 with no problems..
Old Feb 24, 2003 | 09:30 AM
Nuts's Avatar
Default Re: Drawback on lower (vtec.dc2)
I don't quite understand that max. load capacity figure. They said it's 1135lbs for 195/55/15 and 1047lbs for 195/50/15. Is that figure represent the max load PER tire or all 4? I mean R weight about 2639lbs. Any input?
thanks for the info.
CS
Old Feb 24, 2003 | 09:34 AM
Johnny Tran's Avatar
what you are reffering to is per corner....if your civic weighs 4000lbs, contact jenny craig
Old Feb 24, 2003 | 09:38 AM
Big Phat R's Avatar
Default Re: Drawback on lower (CS)
CS
That's static load. Dynamically speaking the front tires will undergo several times that weight.
IMO the Type R is undertired stock. Putting on even smaller tires makes things worse. If it's just a daily driver - should be ok.
Sidewall height will be less - so the car should feel "stiffer" around the corners. Rolling circumference will be less too - so your odometer/speedometer will be off too. Acceleration should improve marginally.
Old Feb 24, 2003 | 09:43 AM
jond's Avatar
I'm betting you could get close to 1300lbs on 2 tires in a hard turn, with a disportionate amount on the front tire. I'm heard of people blowing tires in high speed corners because of this. I wouldn't do it. Its not worth the risk.
Old Feb 24, 2003 | 11:18 AM
Nuts's Avatar
Default Re: Drawback on lower (jond)
Kinda freaky. But did that happen on the track or on the street?
thanks,
CS
Old Feb 24, 2003 | 11:32 AM
Dave-ROR's Avatar
I run 195-50-15 S-03's without an issue. On the street and track. I do have a overloaded/bloated GS-R so the weight issue should be worse. IMO for the street 195-50-15's are fine. for track I prefer something wider, 205s or 225s.
Old Feb 24, 2003 | 12:11 PM
jond's Avatar
It was on the street. I think I read it on this forum. If memory server me(doesn't 50% of the time), I think they fliped the car a few times. I think there were something like 2 passangers in the car which obviously raises the weight 300lbs or so.
[Modified by jond, 4:13 PM 2/24/2003]
Old Feb 24, 2003 | 12:19 PM
Dave-ROR's Avatar
IIRC you are talking about a Civic Si. And there were far too many variables in that case. IIRC also it was said that the tires were drastically under or over inflated. I don't recall anymore exactly but there was only that one case that I can recall and there was no evidence that the tires themselves caused the rollover.
Old Feb 25, 2003 | 02:25 PM
TurboR1391's Avatar
My car actually cornered sloppy when I went to 195/50/15s. I like the response much more with the 205/50/15 Azenis.
Old Feb 25, 2003 | 02:29 PM
Dave-ROR's Avatar
Default Re: Drawback on lower (TurboR1391)
were they 195-50-15 azenis? you can't compare 195-50-15 blue light specials to 205-50-15 azenis.
ecahatch
Jan 27, 2006 12:09 AM
tdo
Nov 11, 2005 05:01 PM
Timmy!
Aug 12, 2005 11:35 AM
chi@1001
Apr 20, 2002 01:39 AM
SWEDISH ITR
Mar 22, 2002 06:07 PM
