itr camshafts, need the truth
Old Feb 24, 2003 | 07:40 AM
red civic standard's Avatar
Default itr camshafts, need the truth
is there a difference between usdm and jdm itr cams?
is there a difference between 96-97, 98-99. and 00-01 itr cams?
are there any itr cams that are equiavalent to CTR cams?
Old Feb 24, 2003 | 07:51 AM
delslow94's Avatar
Default Re: itr camshafts, need the truth (red civic standard)
00-01 itr cams have the same profiles as the ctr. otherwise the itr cams are all the same. the jdm cams are the same as the usdm
Old Feb 24, 2003 | 07:52 AM
Nate B's Avatar
god has this been brought up enough?
Old Feb 24, 2003 | 07:53 AM
RTW DC2R's Avatar
Default Re: itr camshafts, need the truth (delslow94)
00-01 cams are different from 97-98 cams. 00-01 cams are the same as JDM CTR cams.
Old Feb 24, 2003 | 07:54 AM
Chris N's Avatar
Default Re: itr camshafts, need the truth (RTW DC2)
RTW said it.
Integra Type-R(Through 1999 Spec)
Int-240 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Civic Type-R And Integra Type-R(Integra Type R 2000/01 Spec)
Int-243 dur. / 11.5mm lift
If you would have searched, even the recent topics, you would have found what you are looking for.
[Modified by Chris N, 10:55 AM 2/24/2003]
Old Feb 24, 2003 | 08:03 AM
EK Ferio's Avatar
Default Re: itr camshafts, need the truth (Chris N)
CTR intake lifting is 11.0mm instead of 11.5mm, If I'm wrong, please correct me.
Old Feb 24, 2003 | 08:06 AM
JDM CTR '00's Avatar
Default Re: itr camshafts, need the truth (EK Ferio)
Civic Type R 11.5mm, duration - 243 @ 1mm 10.5 mm, duration - 235 @ 1mm
Chris N's Avatar
11.5
http://homepages.paradise.net.nz/asmsbm/camspecs.htm
http://www.g-speed.com/pbh/b16a/
https://honda-tech.com/zerothread?id=310946
https://honda-tech.com/zerothread?id=278176
https://honda-tech.com/zerothread?id=269141
[Modified by Chris N, 11:07 AM 2/24/2003]
Old Feb 24, 2003 | 08:13 AM
EK Ferio's Avatar
I'm not sure, I got some data from Japan.
B16B:
IN/EX
Primary 33.13/32.78
Secondary 34.84/34.69
Mid 36.85/36.33
Central angel 101/103.5
Action angel 247/240
Lifting 11.40/10.52
B18CR
Primary 33.08/32.78
Secondary 34.73/34.69
Mid 36.88/36.33
Cental Angel 106.5/103.5
Action Angel 245/240
Lifting 11.45/10.52
[Modified by EK Ferio, 5:19 PM 2/24/2003]
Old Feb 24, 2003 | 08:56 AM
HogNutz's Avatar
All are the same except CTR cams are a bit more aggressive. Most people choose ITR intake and CTR exhaust for maximum power for N/A. Its up to you. Just get all CTR and you will be happy.
Old Feb 24, 2003 | 10:03 AM
SlapSmak's Avatar
Default Re: itr camshafts, need the truth (OG Bizzle)
nope, new topic
Old Feb 24, 2003 | 11:20 AM
rodrez.'s Avatar
Default Re: itr camshafts, need the truth (HogNutz)
Everyone I know would rather have the more aggressive CTR intake cam, as the exhaust cams are the same.
Old Feb 24, 2003 | 11:25 AM
Dave-ROR's Avatar
Default Re: itr camshafts, need the truth (rodrez)
Correct. The exhaust cams are the same. But nice misinformation on HogNutz part.
crackerjacker006
Aug 23, 2005 11:05 PM
animal chin
May 19, 2004 12:13 PM
redline201
Feb 16, 2003 10:23 PM
EJ8 Kenobi
Oct 23, 2002 05:01 PM
PnX-R
Mar 19, 2002 05:42 PM
