So I tried installing my Ingalls Camber Kit and...
Old Feb 23, 2003 | 09:38 PM
ruiner17's Avatar
Default So I tried installing my Ingalls Camber Kit and...
...it doesn't fit right. I got the Ingalls Extreme Front Adjustable Camber Anchor Bolts from iapdirect.com ( http://www.iapdirect.com/item.asp?invid=119 part # 35730 ) for my 88 CRX Si. I removed the stock Anchors from the car and began to replace them with the Ingalls kit. The upper control arms are slightly too small to fit the camber kit in. Did i get the right kit? Anyone else have this problem? See my quick diagram below to see what exactly i mean.
Did i do something wrong here? Do i have to use different upper control arms? Please help.
Thanks
[Modified by ruiner17, 10:39 PM 2/23/2003]
Old Feb 23, 2003 | 09:41 PM
drjondurst's Avatar
Default Re: So I tried installing my Ingalls Camber Kit and... (ruiner17)
I had that exact same problem. The hours I spent hammering the kits into the control arms were so fun! (not really)
Old Feb 23, 2003 | 09:48 PM
ruiner17's Avatar
Default Re: So I tried installing my Ingalls Camber Kit and... (drjondurst)
so whad'ya do? hammer the thing in until it fit??? that sucks... any other options?
thanks for the reply...
Old Feb 23, 2003 | 09:50 PM
drjondurst's Avatar
lol yea thats what I did. It did kinda suck, but I didnt know what else to do. Hopefully once you're done with this you wont have the control hitting the inner fender problem or the opposite.. this:
camber kits would hit the control arms so had to cut the control arms.
Old Feb 23, 2003 | 09:51 PM
shorti's Avatar
use a grinder and shave off a bit of metal
even a little dremel with a sanding disk might work
Old Feb 23, 2003 | 09:56 PM
redzcstandardhatch's Avatar
something different
Default Re: So I tried installing my Ingalls Camber Kit and... (shorti)
dremels with sanding disks really dont work well on beefy metal, or at least mine doesnt! ihatemy dremel........just grind that ****
Old Feb 23, 2003 | 10:29 PM
ruiner17's Avatar
Default Re: So I tried installing my Ingalls Camber Kit and... (redzcstandardhatch)
hmm, i guess i'll take the dremel to the ingalls kit or the upper control arm... that sucks. i didn't know anyone had this problem, else i would have gone with another camber kit. does ingalls know of this problem? or are they just using another application for our setup? hmm...not too happy with ingalls now...
any one else solve this problem without hammering/grinding/#*$&#ing ??
thanks--
Old Feb 24, 2003 | 03:35 AM
Stupid Ass's Avatar
One question, how low is your car?
Old Feb 24, 2003 | 04:52 AM
REDBARON's Avatar
Default Re: So I tried installing my Ingalls Camber Kit and... (SOHC NoTEC)
I installed mine about a month ago, and had to hammer it in. It wasn't that hard. I have the poly bushings so I put some grease on the ends and hammered away. It only took a few minutes on each arm. Seriously, it's not that hard. They are meant to fit snug.
Old Feb 24, 2003 | 05:55 AM
slowpokesi's Avatar
Default Re: So I tried installing my Ingalls Camber Kit and... (REDBARON)
i had to hammer my extreme kit in as well, it wasnt that bad, be sure and get it aligned after your done, you shouldnt have to grind anything, just hammer that bitch like you would the prom queen
Old Feb 24, 2003 | 06:07 AM
paybac4223's Avatar
Default Re: So I tried installing my Ingalls Camber Kit and... (slowpokesi)
sounds like the perfect time for an air grinder...
Old Feb 24, 2003 | 07:26 AM
ZERO COOL's Avatar
New User
Default Re: So I tried installing my Ingalls Camber Kit and... (paybac4223)
I recently installed my ingalls kit as well and yes, you have to knock them into place. I just placed my A bracket, or whatever it's called to a vise clamp and hammered them into place with a rubber mallet. Pretty simple.
Old Feb 24, 2003 | 07:48 AM
Josh.'s Avatar
Default Re: So I tried installing my Ingalls Camber Kit and... (ZERO COOL)
All you guys and your power tools... screw that. I got out the trust ol hand powered file and ground them down a bit.
Old Feb 24, 2003 | 08:14 AM
Eggman's Avatar
That sucks. Is it because those are made to fit so many different cars (ED, EG, DC, DA, Accrod, Prelude...)? I guess I go with Ingalls.
Old Feb 24, 2003 | 08:20 AM
ruiner17's Avatar
Default Re: So I tried installing my Ingalls Camber Kit and... (Eggman)
thanks for the help guys... i'll try the hammering method next time. i didn't take the upper control arm off of the car, so i had a bitch of a time trying to shove the kit in with my bare hands...
thanks again...
Old Feb 24, 2003 | 09:31 AM
incubus's Avatar
i didn't use a hammer I found something that worked better, I used a pair of garden shears ( huge pair, about 3 feet long) stuck the blades in between the control arm and spread them apart. I found this to work very fast, I just made sure I tightened the bolts down real good when I was finished.
Old Feb 24, 2003 | 10:48 AM
FourthGenHatch's Avatar
I had the same problem. I just removed the metal like cylinder thing from inside the bushing and it went in much easier. I haven't had any problems. But now that I think of it I should have locked down some locking pilars onto each side and just pulled as hard as I could to spread them a mere mm or so to get it to fit.
[Modified by FourthGenHatch, 7:49 PM 2/24/2003]
6doorsentra
19
Jul 10, 2007 11:11 AM
eg:R
Aug 17, 2004 07:14 AM
Sandor
Nov 17, 2003 09:01 AM
TwoSaints
Oct 19, 2003 11:27 AM
