Wiring Diagram on 00 Civic Si???
+12 Volts White Ignition Harness +
Ignition Black/yellow Ignition Harness +
Ignition 2 N/A N/A N/A
Accessory Yellow Ignition Harness +
Accessory 2 N/A N/A N/A
Starter Black/white Ignition Harness +
Starter 2 N/A N/A N/A
Tachometer Blue tach test connector (1) AC
Lock Green/white connector at fusebox -
Unlock Green/orange connector at fusebox -
Glow Plug N/A N/A N/A
Parking Brake Green/red At switch -
Clutch Bypass N/A N/A N/A
Doorpin Black/white or green/red connector in driver's kick panel -
Hoodpin N/A N/A N/A
Arm N/A N/A N/A
Disarm N/A N/A N/A
Brakeswitch Green/white At brake pedal switch +
Parking Lights Red/black connector at fusebox +
Trunk Light N/A N/A N/A
Trunk Release N/A N/A N/A
Injector N/A N/A N/A
Hoodpin N/A N/A N/A
Arm N/A N/A N/A
Disarm N/A N/A N/A
TwoFaced
Dec 16, 2010 05:34 PM
