DSM turbo mani. for H23?!
I was reading on HondaStyle.com and saw a post that said you can redrill the bolts for a stock DSM turbo manifold to fit an H23! Anyone tried this before?
I highly doubt it, BUT...if you find the gasket from both manifolds, you can kinda compare it to see if it'll fit? At the most, you'll probably need to port the exhaust manifold to match the H23 exhaust ports. Or vice versa.
Apparently someone's done it before, i just couldn't figure out who. They say the exhaust ports line up almost perfectly, so I may give it a try sooner or later, just wanted to see who else has done/heard of it.
And good luck on his FMU + check valve setup.
umm no it does work. maybe that guy is lying for whatever reason, but it will work. I have seen it line up on my f22, you just need to redrill the holes. ports line up fine. this one is not mine, but you see the idea, just redrill holes.
holy ****... now i can go tubular! **** hell yea.... btw h22 uses the same piston as h23.. the compression is different but u know what i mean..... at least JE has same pn for the 2..
[Modified by BoostedH23a1, 8:58 PM 2/24/2003]
well ill be damned! wish i would have known this along time ago so i didnt have to waist money on my crapshop mani.
I believe the holes for f22 and h23 line up also. Can't remember where I heard that though.
[Modified by symba, 2:45 PM 2/25/2003]
