A/C Compressor clutch not engagging. Need some help
Old Feb 23, 2003 | 02:13 PM
Magick211's Avatar
Default A/C Compressor clutch not engagging. Need some help
Ok heres the deal the compressor clutch is not engaging, but if i take a jumper wire and run it from the battery directly to the wire on the compressor it will engage but other then that it wont engage with the wire thats on the harness.
I checked the wire thats on the harness for voltage and it only has around 10 volts, should it be 12 volts?
Old Feb 23, 2003 | 02:47 PM
SiR831's Avatar
Default Re: A/C Compressor clutch not engagging. Need some help (CivicBoyZC)
does the ac system have proper pressure (freeon) on the low and high side?
Old Feb 23, 2003 | 02:56 PM
IceBox's Avatar
Check the relay.
Old Feb 23, 2003 | 03:12 PM
Magick211's Avatar
Default Re: A/C Compressor clutch not engagging. Need some help (IceBox)
i replaced the relay already
Old Feb 23, 2003 | 03:16 PM
IceBox's Avatar
How about the a/c thermostat?
Old Feb 23, 2003 | 04:18 PM
Vinceg99's Avatar
Default Re: A/C Compressor clutch not engagging. Need some help (SiR831)
There is a safety switch and if the pressure is either too high or too low it wont allow the compressor to engage. I would bet that is your problem especially if you can run a hot lead to it and it engages. Take it to a place and have them check it and if its low find out why.
Old Feb 23, 2003 | 04:56 PM
altoid's Avatar
Default Re: A/C Compressor clutch not engagging. Need some help (Vinceg99)
there's a big juicy section in the manual about ac problems, check it out. it should solve all your problems
Old Feb 23, 2003 | 06:29 PM
Magick211's Avatar
Default Re: A/C Compressor clutch not engagging. Need some help (Esquared4)
Yeah i knew about the pressure switch on the lines i havent hooked any guages up to see if it was low but when i used the jumper wire to engage the clutch the a/c was working good so i didnt think it would be low. guess ill get it checked at school sometime
Old Feb 23, 2003 | 07:00 PM
Vinceg99's Avatar
Just because it still blows cold doesnt mean it isnt low.
Zak Greenwell
16
Feb 16, 2023 01:05 PM
JDMaznKID
Jun 29, 2010 07:29 AM
gnccracer20
Apr 26, 2009 07:55 PM
superfuji57
Jul 14, 2007 05:38 PM
forksports
Sep 26, 2003 06:28 PM
