Best Header For N/A B16A
Old Feb 22, 2003 | 10:28 PM
The G2 Racer's Avatar
Default Best Header For N/A B16A
I'm doing a stright N/A build up on a 99 spec B16A. What's the best header for my money. Doing high compression ratio so I want something that flows really good.
Give me your opinions.
Old Feb 22, 2003 | 11:36 PM
Nine's Avatar
Default Re: Best Header For N/A B16A (The G2 Racer)
DC Sports JDM 4-1 is supposed to be a nice and relatively inexpensive header for high reving NA applications. For a little more money try Hytech or SMS.
[Modified by Nine, 8:40 AM 2/23/2003]
Old Feb 23, 2003 | 07:39 PM
137's Avatar
137
Default Re: Best Header For N/A B16A (Nine)
I am told the apexi header is the best of the bunch... you will lose power with the dc 4-1 header.
Old Feb 23, 2003 | 07:47 PM
Default Re: Best Header For N/A B16A (137)
I was looking at the Apex'i header. Good buy?
Old Feb 23, 2003 | 07:48 PM
Chris y0!'s Avatar
hytech is the best... its expensive though
Old Feb 23, 2003 | 07:49 PM
sammysnakes's Avatar
Default Re: Best Header For N/A B16A (Spoon Hybrid)
SMSP
Old Feb 23, 2003 | 07:53 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Best Header For N/A B16A (chainsaw)
I currently have the JDM 4-1 but I am looking at the T1R header.
Don't wanna spend **** loads of money but I want something that flows good. Guess I should have said that from the start.
Old Feb 23, 2003 | 09:27 PM
stockegsix's Avatar
jdm ITR w/ heatshield
Old Feb 23, 2003 | 09:34 PM
deepnite's Avatar
Default Re: Best Header For N/A B16A (zzZZzzleeperCX)
just about any 4-2-1 should work out for u..if u beleive all the test..ud probably pick up a DC Sports
Old Feb 23, 2003 | 09:36 PM
Nine's Avatar
You might lose some mid range power but you'll get quite a bit more up top.
Old Feb 23, 2003 | 09:43 PM
EG*MonKEY's Avatar
don't bother going N/A with a b16 u wont get that much out of it... b16 are good for turbo because they are very strong but the 1.8 and 2.0 blocks will give u a good amount of displacement for N/A power
Old Feb 23, 2003 | 09:46 PM
acydphryck's Avatar
SMSP
what the??? that's a 3 month waiting list if you want that header and if you have $1,000 burning a hole in your pocket. go with a 'jerry rig' JG Header....it's dyno proven to give +6 hp more than the JDM ITR header...dyno sheets are up in http://www.importreview.com
Old Feb 23, 2003 | 09:55 PM
SOHC_DK.'s Avatar
Default Re: Best Header For N/A B16A (acydphryck)
I say that the best Dyno numbers i have seen is by the "Supersprint" exhaust system!!!
M. Nielsen
Old Feb 23, 2003 | 10:01 PM
.Ryan's Avatar
Don't Trust Anyone
The welds on the IB JG header look like crap. You can do better yourself. Someone on here made a thread about it.
Old Feb 23, 2003 | 10:04 PM
greebler's Avatar
DC sports always Dynos higher than anyone else for some reason. On one test comparing pretty much everyone, the Mugen header was almost at the bottom. Go figure, but go with the 4-1 one piece header
Old Feb 23, 2003 | 10:08 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: Best Header For N/A B16A (greebler)
Damn only if this link still worked. And NO dc wasnt on top.
http://www.automotiveperformanceengi...om/header.html
Old Feb 24, 2003 | 09:36 AM
SOHC_DK.'s Avatar
Default Re: Best Header For N/A B16A (SpoonSportsEH2)
This a Danish Dyno, of an Civic VTI , it's the EG hatch with the B16A2 engine.. only equipped with Supersprint header and catback.. and a cai.
The Hp (HK) is meassured on the FLYWHEEL not on the weels like you do.. I would say theese are the best numbers I have seen..
M. Nielsen
[Modified by SOHC_DK., 7:37 PM 2/24/2003]
Old Feb 24, 2003 | 09:42 AM
743power's Avatar
Default Re: Best Header For N/A B16A (SOHC_DK.)
holy wow, that vti turned into a high revving beast with a very smooth powerband with just exhaust and header. VERY impressive. As far as headers are concerned, I would be thinking long term. A header with a 2.5" collector is going to flow more and provide more top end, but if your car is still pretty much stock, you're going to loose alot of bottom end, which we all know theb16 is lacking in. I would PM smsp on this board. His headers are pieces of art, and the "gsr" header is more like 700, not $1000. Plus, he'll learn you're personal setup and needs, and build the perfect header for your setup.
Old Feb 24, 2003 | 10:06 AM
JSPECEX's Avatar
jdm 4-1 is really nice i got dc i am so pissed at myself they suck so bad it didin't give me any change at all. they also sound like pieces of **** the jdm on the other hand sound mean as hell
Old Feb 24, 2003 | 02:50 PM
kingspeedracin1's Avatar
i had lsvtec with full stock exhaust. 154.6 hp at the wheels.
put a jdm dc 2.5" collector, 2.5" cat, 2.5" custom exhaust 171.8 hp(3rd gear gsr tranny)
that header is a good header
after porting head and manifold, and skunk cams 195hp(3rd gear 99si tranny)
Old Feb 24, 2003 | 03:26 PM
hatchdrvr's Avatar
Default Re: Best Header For N/A B16A (kingspeedracin1)
you guys are leaving out the Comptech 4-2-1---->makes lots of torque and good HP just what a B16 needs. But then again you said you don't plan on spending alot of money.
Old Feb 24, 2003 | 03:32 PM
dfoxengr's Avatar
Default Re: Best Header For N/A B16A (hatchdrvr)
Ericks racing
Old Feb 24, 2003 | 03:40 PM
-Whitey-'s Avatar
Default Re: Best Header For N/A B16A (hybridvteceg)
i have the jdm dc sport 4-1 header its worth the money imho
Old Feb 24, 2003 | 03:44 PM
rainmanEK's Avatar
big strong guy
No DC was not on top, But The DC was By far the Cheaper of the bunch, And also Proved to be very Worthy!
Eric
