Check this out 1.4L SOHC N/A - 13.9sec
Old Feb 22, 2003 | 07:32 PM
jt-sport's Avatar
Default Check this out 1.4L SOHC N/A - 13.9sec
http://photos.yahoo.com/jt_sports98
Im one of Bisimotos Ezerioha fans
-D13B sohc non-vtec
-1.400cc 76.5 bore x 76 stroke
-13.1 : 1 JE-Pistons
-Crower Conrods
-Ported n polished
-Gude Bullfrog 328 cam
-dual Weber 45mm
-DC 4-1 Header
-4 speed close ratio gearbox
-Cusco LSD
-20x9x13 M&H racemaster
13.9sec @ 101 mph
shift @ 9400rpm
Cheers
Old Feb 22, 2003 | 07:39 PM
Diablo Tejano's Avatar
Default Re: Check this out 1.4L SOHC N/A - 13.9sec (jt-sport)
This album is currently empty.
Sounds pretty sweet tho...
Carbs
James
[Modified by bluboy, 10:39 PM 2/22/2003]
Old Feb 22, 2003 | 11:09 PM
h45454's Avatar
Default Re: Check this out 1.4L SOHC N/A - 13.9sec (bluboy)
props to you bud
Old Feb 22, 2003 | 11:58 PM
Hayasa15's Avatar
Default Re: Check this out 1.4L SOHC N/A - 13.9sec (h45454)
Where are you located at? What cars does the 1.3 come in and where did you get a close ratio 4 speed?
Old Feb 23, 2003 | 12:07 AM
FullMetalJacket's Avatar
Default Re: Check this out 1.4L SOHC N/A - 13.9sec (Hayasa15)
car is jdm...rhd and ef front..must be base model jdm hatch
Old Feb 23, 2003 | 03:37 AM
1.8Tities's Avatar
Default Re: Check this out 1.4L SOHC N/A - 13.9sec (FullMetalJacket)
awesome!!! d series power y0!
Old Feb 23, 2003 | 04:11 AM
jt-sport's Avatar
_______
Im living in Jakarta/Indonesia
D13B was "old" ASEAN (singapore,malaysia,indonesia,etc) domestic market
I made this close ratio gear at gear fabrication company in my city, it was 5 speed but i only change 4 gears ratio, as this car will finish only at 4th gear. so i kept the 5th gear on it standart.
Old Feb 23, 2003 | 05:01 AM
USDM 4G VTEC's Avatar
my props to that guy
nice and tight *** setup
Old Feb 23, 2003 | 05:32 AM
crx(gator)'s Avatar
nice hatch...that rocks...
sweet VR4...man i want one...
Old Feb 24, 2003 | 08:42 PM
StorminMatt's Avatar
Default Re: Check this out 1.4L SOHC N/A - 13.9sec (4thGSi)
The 1.3 is not a D-series motor. Although it is actually similar to the VERY early D-series motors, it is actually an EV-series motor. The 1.3 was found in the 1984 and 1985 base model Civic and CRX HF.
Old Feb 24, 2003 | 08:55 PM
illi Adik's Avatar
wow
Old Feb 24, 2003 | 09:02 PM
crx(gator)'s Avatar
Default Re: Check this out 1.4L SOHC N/A - 13.9sec (StorminMatt)
hmm, i think your wrong there matt...not only did the owner say its a d-series engine, but they do have d13 and d14 in europe and asia in the EF chasis...
Pinho
Jul 19, 2008 12:54 PM
maxwellsohc
Jun 29, 2008 08:05 PM
jt-sport
Feb 25, 2003 05:06 PM
jt-sport
Feb 24, 2003 12:38 AM
12SecHatch
Sep 27, 2002 04:41 PM
