master and slave cylinder.
Hey,
I was wondering where the slave and master cylinder are located. I have a GSR and may need to get them replaced or repaired. Also how much would I be spending if I get it replaced by the dealer. I wonder if they will cover it in my warranty. It's a 2001 integ.
Thanks
Thanks
On Preludes, the master cyclinder is connected to the clutch pedal and the slave cyclinder is on the tranny. Its probably the same with GSR's
[Modified by prelude1897, 11:11 PM 2/22/2003]
Master is on the firewall, in front of the clutch pedal. Look for the clutch fluid reservoir...
Slave cylinder is mounted on the bellhousing, about center-height, behind the RH radiator fan. The push-rod from the slave is inside a rubber boot; pull that open & you can see the throw-out lever/fork which goes in to work the throw-out bearing.
siregcivic
Oct 16, 2005 07:55 PM
tbonez
Jun 12, 2005 05:27 PM
-BlueGSR-
Dec 21, 2002 07:30 AM
