Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
STS sway bar options Type R with BSQ kit
Old Feb 22, 2003 | 06:46 PM
JSR3STS's Avatar
Default STS sway bar options Type R with BSQ kit
The rule states
17.7. ANTI-SWAY BARS
Any anti-sway bar is permitted. Bushing material, method of attachment, and locating points are unrestricted. This does not authorize removal of a welded-on part of a subframe toa ccommodate the installation. Components such as anti-roll bars and strut housings which serve dual purposes by also functioning as suspension locators may not be modified in ways which change the suspension geometry or steering geometry
So removal of those nuts takes you out of STS???? Yes or no?? any tech inspectors know? You have to knock off the welded on nuts to install the type r rear bar.. so this takes me out of STS
[Modified by JSR3STS, 3:47 AM 2/23/2003]
Old Feb 22, 2003 | 08:07 PM
Tweakmeister's Avatar
Default Re: STS sway bar options Type R with BSQ kit (JSR3STS)
I was under the impression that it does take you out.
Old Feb 22, 2003 | 08:27 PM
Eee Pee's Avatar
Default Re: STS sway bar options Type R with BSQ kit (Tweakmeister)
Good question....
My question is, since some of the 5G hatches (and others I assume) came with the nuts, and some didn't, who can really make that call?
I would assume it could go either way if the other chassis' are the same.
Old Feb 23, 2003 | 09:39 AM
Shmeek's Avatar
Default Re: STS sway bar options Type R with BSQ kit (Eee Pee)
Technically, it'd be illegal to remove the nut. But if anyone protested you on that, I'd be extremely surprised.
There's also the part about being allowed to do some updating/backdating. If you can ud/bd to a car that doesn't have the nut, then removing it may be legal.
Old Feb 23, 2003 | 03:35 PM
JSR3STS's Avatar
Default Re: STS sway bar options Type R with BSQ kit (Shmeek)
So Im guessing ill be fine, but i was just wondern when i was reading the rules the other day...
Any tech inpectors know??
JAYBOOGIEZZ
May 10, 2007 10:29 AM
Mushvroom
Feb 17, 2005 10:44 PM
eg64u
Mar 31, 2004 01:12 PM
JSR3STS
Feb 22, 2003 10:26 PM
01gizzer
May 29, 2002 01:27 PM
