axles problem!!
Old Feb 22, 2003 | 05:28 PM
iwouldHITit's Avatar
Default axles problem!!
im doing a b18b swap in my crx HF. i just pick up some Si hubs and when i got home i tested my axles(91tegs) to see if the fit...and guess what it does want to go in..help!?!?
Old Feb 22, 2003 | 05:32 PM
turbohf's Avatar
Default Re: axles problem!! (iwouldHITit)
does it look close? you try cleaning the axles and insides of the hubs with a wire brush?
Old Feb 22, 2003 | 06:43 PM
Malgerus's Avatar
Default Re: axles problem!! (turbohf)
I don't know if this really applies here, but you do have to remove the dust shield when you're installing the axles...
Old Feb 22, 2003 | 07:34 PM
50shotRex's Avatar
maybe the axles came out of an abs teg?
Old Feb 22, 2003 | 07:37 PM
Default Re: axles problem!! (50shotRex)
ok..one axles goes in but the other axle does not go in... would it matter if it was from a 94+ teg?
Old Feb 22, 2003 | 07:56 PM
turbohf's Avatar
nope those will fit too...
Old Feb 22, 2003 | 07:59 PM
brian g's Avatar
Any 1990-2001 Integra axle has the same spline count as any 1988 or later Civic/CRX Si. If yours doesn't fit, either the axle is wrong or damaged or the hub is.
brian g
2x0
16
Sep 21, 2017 05:13 AM
grg9988
Mar 7, 2008 04:11 PM
alupso
28
Mar 2, 2007 12:17 PM
allmotorlsvtecrx
Feb 19, 2004 06:58 AM
H23vtecEG
Feb 4, 2003 10:15 AM
