How to make turn signals bright
Old Feb 22, 2003 | 03:25 PM
ITSFEROZ's Avatar
New User
Default How to make turn signals bright
I have a 97 integra and want to know how to make my turn signal bright and blink quick without heating out my turn signal from the inside or melting anything
Old Feb 22, 2003 | 03:28 PM
VTECorona's Avatar
Default Re: How to make turn signals bright (ITSFEROZ)
You can go about it the rice-boy method. Superwhites :x
Old Feb 22, 2003 | 05:35 PM
xteg95's Avatar
I know if you take the outer blub from the corners the inner will blink really fast (or otherway around...I forgot)
Old Feb 22, 2003 | 09:21 PM
ernald711's Avatar
dude i don't really kno what u mean by wanting to make them brighter. But yeah you could get some clear corners and hyper white bulb or something. If you've done that and ur not satisfied (or they look yellow), it's cause they're double fillaments and only go off when u signal. about the quicker signals, you could go the ghetto way (like i did before) and cut your wires, the only thing is that your tail lights blink faster, but your fronts don't blink. They also have kits where you could adjust the rate of the blink to rally, race, etc. In my opinion, you shouldn't do this at all.
Old Feb 22, 2003 | 09:32 PM
Al Bundy's Avatar
I made mine brighter with a relay, but it makes your blinkers faster. All good though, I like it being brighter.
[Modified by Al Bundy, 10:33 PM 2/22/2003]
Old Feb 22, 2003 | 10:13 PM
iH8RICERZ's Avatar
Default Re: How to make turn signals bright (Al Bundy)
HYPER white bulbs.....if you want brighter..not sure how to do the fast blinker crap though! good luck
Old Feb 22, 2003 | 10:22 PM
Deluzional's Avatar
Default Re: How to make turn signals bright (iH8RICERZ)
I know 2 methods you can do to make your blinkers quicker. You can either buy the relay which you switch out for the old, or you can go the other route by locating the black wire in your turn signal harness and cut it, you could rewire it if you want it to go back to normal...I personally did the relay, but my friends have cut their wires
Old Feb 22, 2003 | 11:07 PM
simplegreenmachine's Avatar
hyper blinkers
Old Feb 22, 2003 | 11:13 PM
AllB18C406's Avatar
use smaller bulbs in your taillights i forgot the number. Old school saw it in the early 90's
Old Feb 23, 2003 | 09:21 PM
[TRB]RHD-DC2-TypeS's Avatar
ya i heard that cuttin the ground was bad and would fry the relay after time, but it'll take awhile so cutting it isn't bad
Old Feb 23, 2003 | 11:28 PM
thaiphob's Avatar
Nikon!!!
just buy the hyper blinker off Ebay! problem solved.
Old Feb 24, 2003 | 01:09 AM
:jdmshmaydm:'s Avatar
Default Re: How to make turn signals bright (thaiphob)
Yikes you want a turbo blinker? I know if you take out the inner bulb in the front bottom reflectors that the rear signal will blink fast. The front will no longer blink though.
Get some clear corners and some hyperwhite bulbs and I think you should be ok as far as brighter signals. In the front that is. As for the back, you could get hyperwhite signals there too. I personally am not a fan of the fast blinker though.
Old Feb 24, 2003 | 04:27 AM
DC2Slow's Avatar
i cut my black wires...if i get extra money ill buy some hyperwhites c if they get brighter.
corps
Feb 1, 2011 12:13 PM
JDMEK-4
Mar 30, 2010 05:16 PM
DOHCter VTEC
Apr 29, 2008 01:55 PM
jwork101
30
Jan 15, 2003 02:06 PM
4wsB21a
Feb 12, 2002 05:56 PM
