Possible to have the corners as only turn signals?
Is it possible to wire up the parking lights so that they only blink when teh turn signal is on? I'd like to make it so that they dont stay illuminated while driving.
Thanks
Jim
Thanks
Jim
Re: Possible to have the corners as only turn signals? (dwnthehatch)
Just cut one of the wires off of the socket.
Re: Possible to have the corners as only turn signals? (burp)
if it's for the 5th gen, yes. if you take your bulb out you will see two little nipples on the bottom, one is for blinking and the other is for the parking lights. If you just take some electrical tape and tape over the nipple that controls the parking light they'll only blink when you turn on your turn signal...i've been running this setup for over a year now on the same bulbs and have had no probs at all....
Re: Possible to have the corners as only turn signals? (95hbMatt)
oh and for cutting wires....
if you ever want to go back to the original setup all you have to do is remove the piece of tape....
Re: Possible to have the corners as only turn signals? (formulaEH2)
Thanks for the tip. I gonna try that. I cut my wires once and I totally regretted it afterwards!
anyway, does anybody know how to do this on a 6th gen? i also wanna get rid of the "always on" parking lights. and a faster turn signal would kill me
Re: Possible to have the corners as only turn signals? (Spoon Hybrid)
Re: Possible to have the corners as only turn signals? (iriemark)
i have a 6th gen as well and want to know to do this the right way.
ok, so if i cut the wire, my turn signals will work just as good as they do now, without turning on when my headlights are on? which wire do i cut?
i did the tape trick back in the day when i had a EG, but then people kept on changing lanes into me, because they didn't see me. so i took off the tape and put the corners back on. i have to admit tho, it does look good without the corner bulbs on all the time.
Re: Possible to have the corners as only turn signals? (Airbag Club)
does this help you? http://www.jdmfan.com/technical/cosm...uropean_lights/
True, but then you have that annoying hyper-blink action... AND it blinks dim. Does anyone know how to do it so that it blinks normal? I've always wanted to know this as well.
Re: Possible to have the corners as only turn signals? (94hondaLS)
or just visit the link i posted above.
all you do is remove the steering column covers, find a big white plug, and switch two wires that go into it. I think i'm going to do it tomorrow.
Re: Possible to have the corners as only turn signals? (Daniel)
i don't think you should cut ANY wires. instead, remove the bulb, and look into the plug socket. use a pin and kind of push the connector up and out of the socket. it is so much better doing it this way than cutting, because at least if you change your mind later, you can just simply plug back in the wire. much cleaner IMO.
jdm headlight setup thats the way it is, the corners are only turn signals and parking lights are inside the headlights. jdm may be played out to some people, but certain parts are still cleaner than usdm counterpart i.e. headlights and corners
u just cut the parking light wire...on 6th gens its the red wire w/ black stripe coming out of the socket...its not gonna make ur signal blink faster and its not hard to re-connect the wires afterwards if u wanna change it
thanks daniel, you da man
So here's what it does when you rotate the exterior lights stalk:
*off* -- duh!
*position 1* -- ONLY headlights come on
*position 2* -- headlights, taillights, and license plate lights come on as well as guage lights and dash lights.
*flick for high beam* -- same as position 2 EXCEPT headlights are brighter and ... the bad part ... dash lights and gauge lights turn off. oh well. . . .
but now the turn signal lights WILL NOT activate unless for signaling or for flashing the hazards. Looks pretty cool, IMO.
didnt realise that usdm was like that...! always wondered why in some pics the corners where on? glad dont have to worry bout that 'cose that'z a bit ghey...just my $.02
