I Need To Build an Engine - What's Best???
Old Feb 22, 2003 | 11:22 AM
Jon Black's Avatar
Default I Need To Build an Engine - What's Best???
OK here are the specifics:
Car -- 1993 Civic DX HB with Auto Trans
Budget -- $5000 for engine - I have the Auto->Man swap in progress
Goal -- To run high 12s in 1/4 mile - want a street car with reliabilty
Dilemna -- Dont know what what engine to run or whether to use turbo or supercharger or NOS - am willing to use any combination within my budget
Long Term -- Basically I want to build this project to compete with my father on the track, have fun with it for a year, and then buy myself a CTR RHD.
If anyone can make suggestions based on experience please comment. For those who want to suggest something and have never done it or helped somebody do it please dont respond. Im looking for facts and hard numbers and suggestions from knowledgable people.
Thanks for sharing your knowledge, I look forward to seeing what you guys suggest.
Jon Black
Old Feb 22, 2003 | 11:23 AM
steve_s's Avatar
Default Re: I Need To Build an Engine - What's Best??? (Jon Black)
I would go b18c1 and get nitrous.
Old Feb 22, 2003 | 11:24 AM
dfoxengr's Avatar
mild build b16 and entry level turbo...should run right at ur budget too..
Old Feb 22, 2003 | 11:29 AM
silverEH2's Avatar
Default Re: I Need To Build an Engine - What's Best??? (hybridvteceg)
LS-Turbo
Old Feb 22, 2003 | 11:32 AM
Jon Black's Avatar
Default Re: I Need To Build an Engine - What's Best??? (silverEH2)
LS/VTEC Turbo or just LS Turbo?
Old Feb 22, 2003 | 11:45 AM
romeo619romeo's Avatar
b18c w/ ctr pistons and cams port and polish with 5 angle on the intake side and 3 angle on the exhaust side of the valves.. good race gas.. and I.H.E. with some cam gears and FPR set at around 48 at idle stock ecu that should get you to 12's.. did for my homeboy... good tire would help too the rest is on your driving..
Old Feb 22, 2003 | 11:48 AM
Nine's Avatar
LS-Turbo
Old Feb 22, 2003 | 12:00 PM
Nata$'s Avatar
LS-Turbo
simple and clean
Old Feb 22, 2003 | 02:24 PM
Jon Black's Avatar
Default Re: I Need To Build an Engine - What's Best??? (QwkEHtwo)
Any other suggestions?
What year LS - B18x (which one)?
Jon Black
Old Feb 22, 2003 | 02:41 PM
RS_91's Avatar
B18 + sc + nitrous
or
b16 + turbo + nitrous
94HybridEX's Avatar
Jon Black
B18b1, OBD I LS.
Old Feb 22, 2003 | 04:07 PM
Foozball26's Avatar
Default Re: I Need To Build an Engine - What's Best??? (xUF EMT FFx)
you're not going to build a 12 sec reliable car for $5k, that will get you an:
LS engine with a basic turbo kit.
GSR engine with nitrous
I wouldnt even think of the b16, it lacks the torque you need.
save a little more and b/c 5k wont get you 12's and still be reliable. unless you spray like 100 shot then you cut down on reliability
[Modified by foozball-26, 7:08 PM 2/22/2003]
Old Feb 22, 2003 | 04:08 PM
Plan B's Avatar
Default Re: I Need To Build an Engine - What's Best??? (foozball-26)
gsr + used jrsc.
Old Feb 22, 2003 | 04:13 PM
shonnys92si's Avatar
Default Re: I Need To Build an Engine - What's Best??? (Plan B)
in my opinion gsr is the best, buy it swap it in stock. drive it 4awhile then it will come natural what u want to do with it.
Old Feb 22, 2003 | 04:56 PM
SIUL8R's Avatar
Default Re: I Need To Build an Engine - What's Best??? (shonnys92si)
Go LS wit gsr tranny and a Drag Turbo Kit
Old Feb 22, 2003 | 05:34 PM
JDM_Sol's Avatar
Default Re: I Need To Build an Engine - What's Best??? (SIUL8R)
for the budget that'll work
Old Feb 22, 2003 | 07:18 PM
Jon Black's Avatar
Default Re: I Need To Build an Engine - What's Best??? (JDM_Sol)
What years did the B18B come in?
Jon Black
Old Feb 22, 2003 | 07:43 PM
dfoxengr's Avatar
b16 is fine with a turbo...
Old Feb 22, 2003 | 07:44 PM
dfoxengr's Avatar
Jon Black
94+ integra LS, RS, GS
Old Feb 22, 2003 | 07:53 PM
Jon Black's Avatar
What about H22? Is it worth the trouble to install?
Jon Black
Old Feb 22, 2003 | 08:11 PM
dfoxengr's Avatar
no...bseries can be ust as good for the same u put into an H22, but theyre kinda sexy, lol
Old Feb 22, 2003 | 08:12 PM
Jon Black's Avatar
So an LS is better than a B16 even thought the B16 has a higher HP output?
Jon Black
Old Feb 22, 2003 | 08:13 PM
dfoxengr's Avatar
no i would do a B16 swap over LS...
Old Feb 22, 2003 | 08:21 PM
Jon Black's Avatar
Im kinda thinking GSR with a used JRSC. What about engine management? Will it need much standalone stuff?
Jon Black
Old Feb 22, 2003 | 08:57 PM
pennies_hatchie's Avatar
1. b18c5 swap - 4000
2. skunk2 stage 2 cams and valvetrain - 1000
with it properly tuned, you should be able to get into the 12's easily
