removing A/C evaporator in cabin?
i was considering removing the big black box under the dash for the AC. i consulted my helm and it looks pretty simple, however i was wondering where the blower and the filter are. in other words, if i remove this piece, will my heat still work? is the blower/filter to the left or right of the evaporator? also, is there even a filter inside or am i just making this up? i couldnt find such in the helms but i thought most cars had them.
yes there is a filter on the big black box.
I believe the car uses that box as a heat duct when the heat is on. Or else the blower wouldn't be moving air through the heater core. What I did was take the evaporator box out and remove all of it's insides. Then put the black box back, now it's just a hollow heat duct.
thats what i was thinking would happen because isnt the blower before the evaporator in the airstream? half of the reason of removing this piece is so that i can gain some under-dash room for electronics. but if i have to put the empty box back , that wont save me any space
get that section out of a non-ZC car its smaller...
i just did this on my civic. i removed the black box with the a/c components and replaced with one from a non a/c civic. probably saved 10 pounds. the non a/c black box is just a tube.
If it works the way I think it does, the blower would be blowing into the cabin at the passengers feet and there would be no air flow through the heater core.
gnxfan
Jul 24, 2005 09:41 AM
