B18c --> 84mm, 84.5mm or 85mm?
Old Feb 22, 2003 | 08:58 AM
Propulsion's Avatar
Default B18c --> 84mm, 84.5mm or 85mm?
84.5 is just under 2 liters right? What are your thoughts on which one is the best choice? displacement vs. reliablilty...
Old Feb 22, 2003 | 09:04 AM
zCivic's Avatar
Default Re: B18c --> 84mm, 84.5mm or 85mm? (SilverCIVIC96)
well a B20 uses 84mm pistons so would say 84.5 would be a hair over 2ltr. B18's use 81mm pistons. Hope this is what you was looking for.
Old Feb 22, 2003 | 09:38 AM
TimoneX's Avatar
New User
Default Re: B18c --> 84mm, 84.5mm or 85mm? (zCivic)
84mm is 1933cc 84.5 is 1956cc 85mm is 1979cc 86mm is 2026cc. I went with 85mm to allow 1mm for future boring/honing.
Old Feb 22, 2003 | 11:11 AM
dfoxengr's Avatar
85 definatrely....more dispacement is better, adn nothing wrong with the reliability
Old Feb 22, 2003 | 11:24 AM
TimoneX's Avatar
New User
Default Re: B18c --> 84mm, 84.5mm or 85mm? (hybridvteceg)
Agreed. If you don't mind the additional expense then you could go with GEs godzilla sleeves which is $100 more. GE claims that'll do fine with up to 86mm. Course if you go with 86mm then you'd have no room to bore if something scarred your cylinder walls. You'd have to re-sleeve again.
In retrospect this may be the best solution however as the cost of going from 85-86mm later is not much less than re-sleeving anyway, because you'd require new pistons. Of course downtime would increase. Whichever you're most comfortable with, I believe all of these options done properly should have little effect on reliability.
Old Feb 22, 2003 | 11:46 AM
dfoxengr's Avatar
Default Re: B18c --> 84mm, 84.5mm or 85mm? (TimoneX)
u can always goto 86.5(ok for street) or 87(which is normally unstreetable)
Old Feb 23, 2003 | 07:00 PM
Propulsion's Avatar
so definitely go 85mm?
sounds good
whats the difference between the godzilla sleeve and the regular one?
Old Feb 23, 2003 | 09:28 PM
boosted hybrid's Avatar
I am curious as to how you are getting a 86mm bore on a gsr will yield 2020cc's? By the defintion of displacement i am getting an 86mm bore on a gsr yields 2095cc's.
Old Feb 24, 2003 | 04:51 AM
TimoneX's Avatar
New User
sounds good
Yep.
From what I've gathered there's no difference in the sleeves themselves only in the way GE sets them up. For only $100 more if you can get a warranty from GE for 86mm then that may well be the way to go, whether you go with 85mm bore or 86mm.
Old Feb 24, 2003 | 04:58 AM
TimoneX's Avatar
New User
Default Re: B18c --> 84mm, 84.5mm or 85mm? (boosted hybrid)
Couldn't tell ya. I get 2026.3. None of this is perfect of course.
PARADOX_sf
Oct 16, 2010 07:57 PM
Propulsion
Sep 28, 2003 12:21 PM
Train
Jun 17, 2003 07:09 AM
ITRbroham
Feb 18, 2003 06:11 AM
