problems with 205/50/15?
Old Feb 22, 2003 | 08:16 AM
crxdevelop's Avatar
Default problems with 205/50/15?
i have a 91 crx si with 205/50/15 nitto nt 450 on konig heliums. it is lowered 1.8 in the rear and 2.0 in the front with neuspeed springs (stock struts). i love the way my crx handles, but when i push it to the limit through a turn my rear tire(s) rub on the back fender(s). what can i do other then rolling my rear fenders. would it help to get new adjustable struts?
Old Feb 22, 2003 | 08:20 AM
xcathodex's Avatar
Default Re: problems with 205/50/15? (crxdevelop)
i think maybe part of the problem is that you're driving 205s on a car that came with 165s or 175s and rode 2" higher. drop down to 195s and you'll be fine.
b16_madman's Avatar
get smaller wheels...no...umm...er just pull the fenders a little...be careful though...r they tucking or what?
Old Feb 22, 2003 | 08:33 AM
crxdevelop's Avatar
Default Re: problems with 205/50/15? (B16_madman)
they are tucking only until they start to rub on the fender. i know i really should have got 195's in the first place, but some one told me that 205's wouldn't be any problem. ok, so then other then getting all new tires, what could i do. would stiffer shocks solve the problem?
Old Feb 22, 2003 | 08:38 AM
b16_madman's Avatar
i am running (not 15's, but 13's ) and was lowered and had no probs w/my 205's rubbing...dont buy new tires...man im gonna go for 225's when i get some h&r spacers....!
heres what i got....
Old Feb 22, 2003 | 09:04 AM
ncrx1's Avatar
roll your fenders..
i run a 15x7 +35 wheel up front, 15x6.5 +38 wheel rear with 205/50's. the fenders need to be only rolled slightly
Old Feb 22, 2003 | 09:14 AM
Overkll's Avatar
It does help to have stiffer springs and shocks, but rolling the fender is free. That's all you'll need to do. If you're not up to rolling the fender, find a place that has a fender rolling tool. They work great and you shouldn't crack your paint like a baseball bat will.
Later, Overkll
[Modified by Overkll, 1:14 PM 2/22/2003]
Old Feb 22, 2003 | 09:38 AM
91_hatch_si's Avatar
Default Re: problems with 205/50/15? (Overkll)
wut is rolling the fender?
Old Feb 22, 2003 | 03:39 PM
escocrx's Avatar
wierd i run 17x7's and i dont git that. most i git is a little in the front when high speed cornering. 205/40/17
Old Feb 22, 2003 | 07:01 PM
Magick211's Avatar
Default Re: problems with 205/50/15? (escocrx)
You can also get the inside of yours wheels shaved to change your offset. Some machine shops can do it. Not sure how much they will charge u though
Old Feb 23, 2003 | 07:32 PM
crxdevelop's Avatar
Default Re: problems with 205/50/15? (CivicBoyZC)
i think i may go with stiffer struts instead of rolling the fenders. has anyone used KYB adjustable struts with neuspeed springs? also, would it improve my turning with adjustable struts?
Old Feb 23, 2003 | 07:46 PM
RacerBoy's Avatar
Default Re: problems with 205/50/15? (91_hatch_si)
I would like to know also.
BTW, I will be running the same size tires (falken Azenis) and will be using H&R sports and AGX's. Will I be rubbing a lot? Will an aftermarket rear LCA help? Thanks!
Old Feb 23, 2003 | 09:55 PM
redzcstandardhatch's Avatar
something different
Default Re: problems with 205/50/15? (RacerBoy)
rolling the fender involves "bending" the lip that sticks in towards your tire (on the fender) inside, at least i believe thats what he is talking about.
Old Feb 23, 2003 | 10:38 PM
ncrx1's Avatar
Default Re: problems with 205/50/15? (redzcstandardhatch)
yup.. just bend the lip back.. if u run your finger along the lip of the fender u can see and feel where your wheel is rubbing. Pull off the rubber liner and take a bat and roll the lip back.. or take a soft hammer, heat gun and tap it back.. put the rubber lip back on and its done.. simple
MurdersV8s
Jun 18, 2007 09:38 AM
type Gendy
May 9, 2007 10:04 AM
White98LS
19
Aug 28, 2006 09:10 AM
b16powwer
Sep 10, 2002 06:31 PM
