Mugen HIGH COMPRESSION head gasket
Old Feb 21, 2003 | 10:50 PM
douglas_be's Avatar
Default Mugen HIGH COMPRESSION head gasket
Anyone installed this gasket ? I am installing it on an European ITR 11.1:1
From what mugen says , it would be 0.4 higher , so that would make 11.5:1
So what would be the difference in throttle responce ? I am also installing Skunk2 stage 2 Camshafts , did any one tried this ? We're also intalling a T/B 70MM and edlebrock intake manifold , spoon header and full exhaust line and take out the catalytic converter. I will be installed next week , WHAT CAN I EXPECT ?
Let me know your experiance.
regards
Douglas
Old Feb 21, 2003 | 11:10 PM
gary201147's Avatar
Default Re: Mugen HIGH COMPRESSION head gasket (douglas_be)
regards
Douglas
I've actually just done a search on this because I am going to put a mugen head gasket on mine. Upping the compression with as agressive cams as Skunk stage 2s should be really good. When going NA compression is probably the biggest factor in improving performance. When you installed it...if you have...did you have to mill teh head? To surface it I mean...are Honda OEM gaskets metal? Would I have a problem if they are not (because Mugen is metal)?
Old Feb 22, 2003 | 06:13 AM
i 4's Avatar
i 4
Mill the head or go with higher compression pistons..use a honda head gasket.
Old Feb 22, 2003 | 06:50 AM
Obee1.8's Avatar
Edlebrock IM? Is that piece really and improvement over the stocker? Just curious,I just thought the stock piece was very good.
Old Feb 22, 2003 | 11:26 AM
92TypeR's Avatar
FSAE
Default Re: Mugen HIGH COMPRESSION head gasket (Obee1.8)
The JG IM flows a lot better after 7k rpms. It is a very top-end oriented piece. I have not heard any bad comments about them.
Old Feb 22, 2003 | 01:06 PM
Big Phat R's Avatar
WHAT CAN I EXPECT ?
It totally depends on your fuel management/tuning.
You will not be able to tell the difference with 0.4 pts of compression. It will help - but the effects won't be noticeable by you.
jdmb18c's Avatar
Default Re: Mugen HIGH COMPRESSION head gasket (92TypeR)
I don't understand how the Mugen head gasket can up the compression by 0.4. The spoon gasket is actually thinner and is suposed to raise it by 0.3. And even then they say that it depends on the mods that have been done to the motor. I have just purchased the spoon one myself. The #'s on the gaskets- Spoon 0.45mm Mugen 0.47mm. The differance is very little so its your decesion. Still a nice little bump to the compression.
Old Feb 22, 2003 | 01:31 PM
nfn15037's Avatar
For an NA motor, its worthless IMO, might as well go with ITBs if you are out-flowing the ITR manifold.
yoorang
16
Nov 12, 2006 04:51 PM
DC5ftmfw
May 20, 2006 01:49 PM
spnfed
Jan 1, 2004 09:03 PM
Spike2
Feb 2, 2003 05:48 PM
snake01
Nov 13, 2002 03:26 PM
