Which Light Flywheel
Old Feb 21, 2003 | 09:44 PM
B20-T's Avatar
Default Which Light Flywheel
which light flywheel for turbo cars?
Old Feb 21, 2003 | 10:17 PM
CzanSOHC's Avatar
Default Re: Which Light Flywheel (B20TURB0)
i like the looks of the new ACT STREETLITE one. I'll prolly be running one in my SOHC setup...Viren is having a killer deal on them.
Old Feb 21, 2003 | 10:20 PM
Pat's Avatar
Pat
Default Re: Which Light Flywheel (CzanSOHC)
yeah the ACT ones are nice looking and well priced. 12.5 lbs for the streetlite, I think I want something lighter like 11 lbs though.
Old Feb 21, 2003 | 10:58 PM
turbod16y8's Avatar
Default Re: Which Light Flywheel (Pat)
which one would be better the 12.5 or their 8.5
Old Feb 21, 2003 | 11:02 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Which Light Flywheel (turbod16y8)
go 12.5 lbs. I had best results with a type r flywheel at 14lbs compared to my now 6lb clutchmaster. you loose a lot of torque with a flywheel that is too light. I'm referring to the street car. i think the 12.5 would be just right.
Old Feb 21, 2003 | 11:05 PM
tegasaurus's Avatar
Default Re: Which Light Flywheel (MotorMatrix.com)
that's why you turn the boost up 1 or 2 psi to compensate for the "loss of torque." Is there actually a loss in torque or is it just ur mind playin a trick on u because it carries less inertia thus it feels less "solid"?
Old Feb 21, 2003 | 11:07 PM
I am a bad person
Default Re: Which Light Flywheel (tegasaurus)
no you definetly loose torque!! as far as turning up the boost goes. imagine if you turned it up 2 more lbs with the heavier flywheel. more tq again.
Old Feb 21, 2003 | 11:09 PM
CzanSOHC's Avatar
Do you think the Streetlite one for a built d16 is good, or should i stick w/ stock?
Old Feb 21, 2003 | 11:17 PM
BoostedGSRBubble's Avatar
You dont loose torque if the weight is properly displaced. Toda is chromemolly and is quick reving at 9lbs and i lost no torque and i have the dyno to prove it.
This was without boost tho.
Old Feb 21, 2003 | 11:21 PM
I am a bad person
Default Re: Which Light Flywheel (BoostedGSRBubble)
My street car is boosted and it lost torque. i went from 14lbs all the way to 6lbs and it lost torque on the dyno.
Old Feb 22, 2003 | 05:45 AM
ekb18c's Avatar
The type r flywheel is the best of both worlds! It's lighter then stock b-series flywheels and it's not too light.
Old Mar 7, 2003 | 05:30 PM
FitCRX's Avatar
Default Re: Which Light Flywheel (ekb18c)
are the R flywheels 14lbs or 12lbs?
Old Mar 7, 2003 | 05:35 PM
CzanSOHC's Avatar
Default Re: Which Light Flywheel (FitCRX)
14lb i think. Someone correct me if i'm wrong.
Old Mar 7, 2003 | 07:15 PM
ninesecrx's Avatar
Default Re: Which Light Flywheel (Boost'R'Us)
Is the one above sfi certified?
The act 12.5 pound flywheel is nice. Its not too heavy at all. More weigh actually helps pull you on the top end because and object in motion tends to stay in mottion. The extra weight also helps control lauches for guys at the track. Its a super good price and it is chromolly. For what its worth...its also sfi certified.
Old Mar 7, 2003 | 07:24 PM
liam821's Avatar
Default Re: Which Light Flywheel (ninesecrx)
i have a jun lightweight for my sohc..and i love it.
liam
Old Mar 7, 2003 | 09:45 PM
FitCRX's Avatar
Default Re: Which Light Flywheel (liam821)
Liam821
JUN
It will be here monday. I also need a clutch kit.
Any running act stage 2 kit for street use, in a midly built b16?
Old Mar 8, 2003 | 02:49 AM
inspyral's Avatar
I ordered an ACT Streetlite from Viren, coming sometime next week
Old Mar 8, 2003 | 06:50 AM
1strdtko's Avatar
Default Re: Which Light Flywheel (inspyral)
You should remember that some clutches can be resurfaced. I don't think you want to replace your clutch and flywheel all the time.
Old Mar 8, 2003 | 07:07 AM
boostedcvc's Avatar
Default Re: Which Light Flywheel (1strdtko)
I havent driven with my new flywheel yet, but im looking forward to it. It's a 9lb spoon flywheel.
Old Mar 8, 2003 | 08:02 AM
bruthaboost's Avatar
Those would be the aluminum clutchmasters/fidanza units. I have a 9 lb one and love it.
Old Mar 8, 2003 | 02:16 PM
BrokenVtec's Avatar
Default Re: Which Light Flywheel (bruthaboost)
open polls......
Fidanze flywheel.......
Old Mar 8, 2003 | 08:14 PM
liam821's Avatar
Liam821
JUN
I used a act xtss with my jun..i loved it!!
liam
Old Mar 8, 2003 | 08:51 PM
V-SPEC 1's Avatar
_______
How much is the streetlite cost?
Old Mar 8, 2003 | 08:52 PM
V-SPEC 1's Avatar
It's 16lbs.
Old Mar 8, 2003 | 11:35 PM
Full-Race Javier's Avatar
Default Re: Which Light Flywheel (B20-T)
i had the fidanza aka JWT 8.5lb flywheel in my nissan. here are some pics....as u can see, its a nice piece, but for the $ i would stick with stock or lightened stock.
