Timing Belt
Old Feb 21, 2003 | 07:41 PM
Sir_Phobos's Avatar
Default Timing Belt
Heard a strange vibrating noise from the timing belt section of the motor, like plastic vibrating, thought it was the timing belt. Took the cover off and sure enough every time i'd give it gas it would rub against the inside plastic cover. How do i tighten the timing belt and what is the right tension? Thanks...
Old Feb 21, 2003 | 10:10 PM
tilt's Avatar
Default Re: Timing Belt (Civic_driver)
retension the tensioner. honda is not specific about how taught it should be, but rule of thumb is 1" of deflection from cam to crank.
Old Feb 22, 2003 | 08:56 AM
TimoneX's Avatar
New User
Default Re: Timing Belt (tilt)
I'd retension it immediately. If it's that loose a little extra noise may be the least of your worries.
laloquera916
12
Sep 27, 2010 08:29 AM
LS_VTECteggy
Jun 11, 2010 01:34 PM
SPIKE'S91CIVICSI
Mar 9, 2009 03:11 PM
B_CRUZ!
Sep 9, 2003 12:20 PM
