my idle is stuck at 4K rpms? why? civic DX
Old Feb 21, 2003 | 07:34 PM
civicracer1993's Avatar
Default my idle is stuck at 4K rpms? why? civic DX
i swapped a 16V DX head onto my cx block and i put the Ex iintake mani and TB and stuff.. and i have a pr4 Obd1 ECU .. when i start the car it idles normal for a sec or two then the idle jumps to 4K .. no matter what ECU i use? why.. it then stays like that ..what could be wrong?
Old Feb 21, 2003 | 08:47 PM
EG1834's Avatar
Default Re: my idle is stuck at 4K rpms? why? civic DX (civicracer1993)
i just replaced the headgasket on my 93 dx and now mine shoots straight to 4k slows down but keeps going, im thinkin it may be a leak in the int manifold. if i ever get it fixed ill let ya know
Old Feb 21, 2003 | 09:10 PM
GARBhatch.'s Avatar
Default Re: my idle is stuck at 4K rpms? why? civic DX (poweredbyrice)
it did something very similar to that with my friends B16 when the mani. was actually cracked. I suppose not getting enough air and the motor tries to make up for it by increasing revs. I suppose a result of too much honing or boring. Those B16s flow well enough already. oh well. Good luck man.
Old Feb 22, 2003 | 10:16 AM
EG1834's Avatar
Default Re: my idle is stuck at 4K rpms? why? civic DX (98Hatch00)
look for vacuum leaks in the hoses, check the MAP sensor to make sure your getting the correct voltage. a chiltons/haynes manual and a multimater will help ya out. It may even be a leak on manifold. run the car and spray wd-40 were the manifold meets the head, if it revs up more, then check gasket. my problem seems to be the purge control solenoid on the manifold, $131.17 from dealership good luck
Old Feb 22, 2003 | 12:03 PM
WangChung's Avatar
air is definately gettin in from somewhere its not supposed to be.
Old Feb 22, 2003 | 12:27 PM
pennies_hatchie's Avatar
Default Re: my idle is stuck at 4K rpms? why? civic DX (97civhatch)
vacuum leak somewhere...
Old Feb 22, 2003 | 05:31 PM
Default Re: my idle is stuck at 4K rpms? why? civic DX (pennies_hatchie)
i just put a new mani gasket on tonight and it still does it.. ? what could be the problem.. all hoses are connected properly. no vacuum leaks. it just does it .. no matter what manifold i put on.. i just replaced the head gasket too and that didnt help/ it starts at like 4k then sometimes will settle at 2k but always when it starts it goes to 4K for a while... i know this aint good.. what is the purge control solenoid. what does it look like .. also what color wires goes to the map sensor and what colors go to the throttle position sensor? i dont think i mixed up the plugs but i dont know.. its a 93 CX..
mike
Old Feb 23, 2003 | 07:06 AM
up
Old Feb 23, 2003 | 06:49 PM
up...
Old Feb 23, 2003 | 07:36 PM
Ya@inlinePRO's Avatar
get some manifold spray cleaner, or brake cleaner, and spray around the gaskets and a the manifold, to find some vacuum leaks....you got one somehwere.
Old Feb 23, 2003 | 08:56 PM
grey16's Avatar
you might need to check the votage on the TPS sesor on the back side of the TB because you swapped the head its probably off. just and idea
Old Feb 24, 2003 | 06:32 PM
Default Re: my idle is stuck at 4K rpms? why? civic DX (grey16)
ok.. its still has the problem but when i pull out the vacuum line from the map sensor it goes down to about 2K it sputters a lil but its better? why is this ? also if the TPS has a diff voltage would that hurt something? i tried to drive without the TPS but it stumbled a lil so i re plugged it in.
mike
Old Feb 24, 2003 | 07:20 PM
grey16's Avatar
Did you try to set the voltage on the tps? If not it has 2 different voltages one when it is wide open and one when it is closed. If you have a repair book it will tell how to do this. You have to set the voltage for both settings. Not sure about the vacuum line why it would do that.
Old Feb 25, 2003 | 06:06 PM
ok. but how exactly can i set the voltage? i never heard of doing that?
Old Feb 25, 2003 | 06:39 PM
grey16's Avatar
i was trying to remeber how to do this and it is...
the tps has 2 screws on it when you loosen these screws you can rotate it just a little when you roatate you will get a different voltage reading on your multimeter.
hooking the meter up you need to have the tps conected(sp?) there is 3 wires that come out of it, you want to put the postive meter cable in the middle wire and ground the black cable to what ever, the car has to be in the on postion not started. as you rotate the tps you will get all sorts of numbers on the meter screen ( I'm going to find out those numbers for you tonight and post them)
But when you find the right setting at wide open and closed postion all you have to do is tighten it back down and reset your ecu. do you have the Breakdown manual? If not get one or borrow one.
Another idea my friend asked just a idea, but your cam my be in upside down just something else to look at.
Old Feb 25, 2003 | 06:55 PM
grey16's Avatar
heres something i found it should help try this and good luck, heres the web site I found it on
http://www.geocities.com/chipman_13/clippings.html
TPS Adjustment:
With the Key On, Engine Off hook up a voltmeter to the TPS. @ idle (closed throttle), voltage should be close to .5V and @ WOT voltage should be 4.5V.
The best way to adjust the TPS voltage is @ idle (closed throttle). While Key On, Engine Off, hook up voltmeter between the yel/wht & grn/wht and observe reading. If it needs to be adjusted, loosen the TPS mounting and move the TPS until voltmeter reads close to .5V. The check engine light will let you know immediately whether you missed up or not.
Jake_eg
Apr 2, 2015 06:03 PM
SPITVENOM67
May 4, 2011 07:56 PM
downburst
Mar 22, 2006 06:39 PM
h22cx
10
Apr 3, 2004 05:56 PM
