A Few Questions about my SI CRX ( Im new also )
Well Hey whats up? im from Honda-acura.net and i heard this board is pretty good for tech Qs!
1. well first off i wanna know how to remove my passenger side door pillar ( where you mount gauge pods ) ?
2. Throw out bearing is shot i think, loud clashing noise made when i push in the clutch..whats the best clutch to get? oem? clutch masters?? looking to spend $200 + not over $350...
3. will post pics is [img] PICTRURE URL [/img] how u do it?
3. will post pics is <IMG SRC=" PICTRURE URL " BORDER="0"> how u do it?
on the armrest. if you dont want it, slang it this way.
i also have 2 other questions....
1. i don't think my cooling fans come on...how can i check to see if they work, and how do i fix them if they dont come on?
2. the other day i turned into park (right side somewhere) and i heard this loud metal bending type of noise?!!! what could that have been..btw it was nothing dragging
-On the pillar removal, just tug on it. It is only held on by clips.
-If I were you, I would get an oem replacement clutch cause you really dont need anything more. My brother got Exedy oem replacement clutch from clutchcityonline.com for $100 shipped. It is a kit so it comes with the throwout bearing and alignment tool also.
Welcome!
Welcome!
hey people i have some more questions for you,....
1.i don't think my cooling fans come on...how can i check to see if they work, and how do i fix them if they dont come on?
2. Leaking from my rear hatch things...where is the sun roof drains? and how do i clean them? or is it something else?
3. Bearign noise in my distubor...easy inexpensive to fix?
AIM: smittylax4 please IM me and give me your ideas and thoughts
thanks!
thanks!
Really the only way to check the cooling fan is to let the car run until it gets hot. The fan should cut on when the car gets to about 200 degrees. put a multimeter on the wires coming to the fan motor when it gets hot to see if there is power going to the motor. if there is 12 volts present, change the fan motor. If not, look behind the motor where the oil filter is located. there is a small plug next to the filter where the block temp sensor it. make sure it is plugged in. if it is not plugged in or faulty, the fan will not cut on.
BTW nice rex. I am looking for a A/C-heater control panel and i see you have an intact one. if you ever feel the need to get rid of it let me know......
keep it clean and save up for a swap
still need these questions answered!
thanks!
thanks!
you can search for #2 to get lots of threads about that.
for #3, you might have to get a new dist...
also, please post responses pertaining to the questions asked. i am sure greenmachinerex knows his car is nice.
hmm...how much do new dist. cost!!!?
where is the search on this web page?
still having trouble with this pillar, how did you all get yours off??!! Exedy clutchs they any good!!?
