stuck axle
Old Feb 21, 2003 | 04:50 PM
OEMaccord's Avatar
Default stuck axle
I am removing the knuckle from my 6th gen accord, but the axle seems to be stuck. I did like my helms manual said and used a plastic hammer to tap out the axle. Well it isn;t working very well. Is there anohter way to get the axle out of the hub?
Old Feb 21, 2003 | 06:22 PM
slomofo's Avatar
GDD Member
Default Re: stuck axle (OEMaccord)
Last resort is to disconnect the upper ball joint, then your lower ball joint, then the steering tie rod, and remove your lower strut fork. Remove the axle and hub assembly from the vehicle, then take it off the hub on a workbench.
boarding2008
Jul 29, 2010 05:56 PM
MartyPike
Honda Civic (2001 - 2005)
Oct 8, 2007 08:02 AM
bigdogc
Jun 10, 2005 07:20 PM
RicedREX
Feb 26, 2004 05:33 PM
