How would you know when your car's wheel bearings are going out....I need help!!!!
My car keeps making this squealing sound in the rear right hub when its running straight and when I turn. The sound comes and goes....What do you guys and gals think it could be???? Let me know thanks.
Jack up the car and see if the wheel wobbles. If so replace the wheel bearings.
ur wheel bearing is going
altho when it started going in my truck, it was a constant humming if i went straight or turned right
if i turned left, the sound went away until i resumed going strauigth
i say check the brakes while your down there it may just be the warning sensor ... but if not then it is the bearing
I found the problem...it was my rear brake pads...so I changed them and the rotors...PROBLEM FIXED...
thanks for all the replies peoples
dj-t
11
Feb 8, 2008 06:03 AM
