please tell me what is wrong...
Old Feb 21, 2003 | 04:00 PM
visual's Avatar
Modified by visual at 11:00 PM 1/5/2007
Old Feb 21, 2003 | 04:42 PM
kotetu's Avatar
Default Re: please tell me what is wrong... (visualvb)
how's your gas level? it sounds like it's low and sediment may also be getting through the fuel filter.
Old Feb 26, 2003 | 11:14 AM
Sephro's Avatar
I would check the connection to the Alt. Maybe it is lose or something. You don't have any fuel leaks do you? Maybe your getting air in the fuel lines?? I don't know. I would also check Distributor cap and wires just to make sure the problem isn't there.
Old Feb 26, 2003 | 02:06 PM
Chinchilla's Avatar
I'm probably wrong but sounds like your fuel filter may be gummed up.
Old Feb 26, 2003 | 03:59 PM
aeolus's Avatar
Default Re: please tell me what is wrong... (Chinchilla)
do you know if any coolant got on the alternator somewhere?
Old Feb 26, 2003 | 05:27 PM
typeSwarrior's Avatar
It does sound like the car is having trouble getting fuel into it's system...maybe you have a bad fuel pump? That may be a possibility...or I could be wrong
Old Feb 26, 2003 | 05:40 PM
Elkins911's Avatar
Default Re: please tell me what is wrong... (typeSwarrior)
i agree, it sounds like your fuel pump.... not any of the other stuff... replace the battery, its always good to have new ones... and if the problem reoccures, then see if someone can test the pump for you.
Old Feb 26, 2003 | 06:01 PM
Quiklude's Avatar
check grounds
Old Feb 27, 2003 | 11:36 AM
Nick H's Avatar
New User
yes it can...your injectors are clogged making your fuel supply limited...this will cause your car to stall, and it is also why you had to accelerate to keep it allive...more fuel had to be pushed in to the engine in order for it not to die...it's logical, just get them cleaned...
Old Feb 27, 2003 | 12:26 PM
Chinchilla's Avatar
pick up some injector cleaner, its only like $3... do you run cheep gas? I found running a couple tanks or 94 octane really once and a while helps!
Old Feb 27, 2003 | 12:39 PM
Boostless97Lude
Guest
Posts: n/a
if you need thwe injectors cleaned that badly, pouring injector cleaner in isn't going to do a lot, you need to take it to a mechainc so they can use a bottle of injector cleaner PRESSURIZED through your system, that way they get good and clean, in order for you to only add a can to the tank, it would take many cans, and a lot of time to run it through the system and still wouldn't be as clean
Old Mar 1, 2003 | 05:30 AM
illusion's Avatar
watch out though.. if its your alternator, then this battery will die very soon and the same **** will happen again.
Old Mar 1, 2003 | 01:43 PM
Sticky Tires's Avatar
* B A N N E D *
test your battery with a multimeter, it should be around 12 volts.
Old Mar 1, 2003 | 02:02 PM
Xlerate9's Avatar
you shouldn't be runnin cheap gas anyway... the tach specifically reads
premium unleaded only.
Old Mar 1, 2003 | 02:23 PM
Xlerate9's Avatar
that sucks... I run super 94 from sunoco... I like buying from them too because they don't import any oil from the middle east
NineT1Lude
Feb 3, 2009 07:57 PM
crnimacak
Apr 21, 2006 10:11 PM
94DOHCDELSOL
May 11, 2005 11:50 AM
Backk InTheDA
Feb 24, 2005 03:52 PM
Krayzielix
Feb 2, 2003 04:12 PM
