how to install sparco pedals
Old Feb 21, 2003 | 02:55 PM
integra6650's Avatar
Default how to install sparco pedals
the instructions for my sparco grips say drill straight through the pedals but there is a bar back there should i slide over to either side?
Old Feb 24, 2003 | 09:46 AM
jhw's Avatar
jhw
Default Re: how to install sparco pedals (integra6650)
Yes, you only need to move the pedals slightly to miss the bar. Just make sure they're straight and that you have clearance for the nut in the back. Tips: pre-drill with a smaller (preferably cobalt) bit to prevent the larger bit from skating; once you get the first bolt on the pedal you can use the other holes in pedal cover as a guide. Finally, I know it sounds stupid but make sure you wear goggles ... bits tend to break and fly out. Good luck!
[Modified by jhw, 6:54 PM 2/24/2003]
Old Feb 24, 2003 | 10:18 AM
Default Re: how to install sparco pedals (jhw)
thank you very much for the help
Old Feb 24, 2003 | 02:12 PM
did it they kinda look like this though \ / l
Old Feb 24, 2003 | 05:54 PM
jhw's Avatar
jhw
You can probably fix this a little if you're not sick of drilling yet. I would widen the bottom hole (or bottom two holes) in the correct direction such that the pedal is straight. To do this, put the drill bit through the hole and apply pressure in the correct direction with the side of the drill bit. Even with the widened holes you should be able to torque down the bolts enough to hold the pedals in place and have them look straight.
[Modified by jhw, 2:55 AM 2/25/2003]
Old Feb 24, 2003 | 06:10 PM
thanks i measured many times and then drilled and came out like that. o well their not horrible and not too noticable
Dc2 Strogg
May 28, 2012 05:43 PM
SPORT INJECTION
12
Apr 19, 2004 05:11 AM
Racer X
Jun 17, 2003 08:52 AM
skygtr01
Mar 24, 2003 09:16 AM
Andrew 825SM
Dec 29, 2002 09:16 PM
