will exedy racing clutch for b17 hold down the power of a b28cR?
the clutch for the 92-93 integra is the same for the b17 and b18.
will the exedy organic racing clutch from 92-93 integra hold down the power of a '00 JDM ITR motor with i/h/e
should I be worried?
Edit: oops. honda doesn't make a 2.8 litre b-series
[Modified by red civic standard, 1:11 PM 2/21/2003]
[Modified by red civic standard, 11:58 PM 2/21/2003]
clutchcityonline says 92-93 is 08-800A and 94-01 is 08-800B but they appear to be the same clutch.
can anyone confirm this?
What makes you say this:
clutch city online lists the b18 92-93 integra clutch the same as the b17 92-93 integra clutch. both are 08-800A
http://www.clutchcityonline.com/main...ura_racing.htm
Get the clutch made for the B18C5.
If you're using a 92-93 GSR transmission, you can use the ITR clutch.
i will be using the 92-93 GSR tranny, but I already have the Exedy organic for it.
Are you sure that you can use an ITR clutch on the 92-93 GSR tranny? Does the tranny have the same size input shaft with the same number of splines?
Reid beat me to it.
[Modified by itec311, 9:43 PM 2/21/2003]
TSIntegra
Jan 11, 2003 09:54 PM
