Brakes: that informercial on TV
Old Feb 21, 2003 | 12:05 PM
kim_2_da_chee's Avatar
Default Brakes: that informercial on TV
i saw an imformercial on TV advertising these small sand paper like sheets that u put in where ur brake pads go, and they guarantee "better than machined" rotors.
it seems too good to be true, but i think i need these.
if some of u remember, i had MAJOR brake problems. I got new rotors, pads, and bled them. I tested it out, and it was fine. However, i noticed that at highway speeds, my car shakes alot (feels like warped rotors) when braking.
I asked the shop that did my brakes, and they told me that it is probably my driveshafts (since they were broken, and making that clacking sound whenever i turn). I believed them, and finally saved up enough money to buy new driveshafts.
Hoping that the "shaking braking" would be gone now, i tried it out on the highway and i was very disappointed since the shaking was still there.
It is not the balancing of the tires because it doesnt shake when driving. I dont have any sort of suspension mods. I have NO IDEA what i could be.
any suggestions? TIA
(sorry this post turned out to be another "help me" thread)
Old Feb 21, 2003 | 12:13 PM
slowman's Avatar
I took way too long
Default Re: Brakes: that informercial on TV (kim_2_da_chee)
wouldn't those only work on the wheel connected to the driveline?
Old Feb 21, 2003 | 12:34 PM
Default Re: Brakes: that informercial on TV (slowmanEF)
i dont understand what u mean.
im just trying to figure out what causes the shaking when braking at high speeds.
It's not just a minor vibration, it shakes so much that it dangers my driving.
so far i got new tires/balanced, new rotors, pads, and driveshafts. i really dont know what it could be that causes such harsh shaking.
im leaning towards thinking that the rotors are warped. but i dont understand why this would be, since they are brand new factory size rotors that were machined very nicely.
[Modified by kim_2_da_chee, 1:36 PM 2/21/2003]
Old Feb 21, 2003 | 12:45 PM
zcivicz's Avatar
possibly they are warped. did you break them (the rotors) in after you got them turned or after you bought new ones ?
Outsane's Avatar
could be your alignment..
and the girl in the pic is damn cute
Old Feb 21, 2003 | 12:46 PM
slowman's Avatar
I took way too long
Default Re: Brakes: that informercial on TV (Outsane)
hahah wow, what i said really made no sense! sorry.
but at my dads house i have all my history records on my car. they had this problem too. i will look at what they did to correct it. i'll tell you later tonite.
edit: yeah, it only happened when they were braking above 70 mph or somen.
[Modified by slowmanEF, 4:47 PM 2/21/2003]
Old Feb 21, 2003 | 12:47 PM
Default Re: Brakes: that informercial on TV (zcivicz)
yes i did break them in. i did a few 50km/h stops while applying good pressure on the brake. i hope that was enough.
Old Feb 21, 2003 | 12:51 PM
thanks man, ya it happens only when braking at 115km/h +
alignment? hmm... i'll look into that as well.
thanks guys
Old Feb 21, 2003 | 12:58 PM
slowpokesi's Avatar
id go with the alignment or maybe your wheel bearings are bad.
Old Feb 21, 2003 | 01:16 PM
90da's Avatar
Did you get factory Honda rotors?? I have seen aftermarket rotors warped right out of the box. Get a shop to do a run-out test on the rotors to see if they are warped. If you got aftermarket ones I would suggest saving money and getting Honda. Makes a big difference.
jjohn6438
Honda Civic (2001 - 2005)
32
May 11, 2009 05:43 PM
kimokalihi
22
Dec 9, 2008 05:29 PM
Lewie
Apr 13, 2005 05:44 PM
ninor
Acura TSX
12
Jan 17, 2005 08:24 AM
ExAcc
Oct 28, 2002 05:57 AM
