problem with ecu swap zc
Old Feb 21, 2003 | 11:28 AM
chirp2hrd's Avatar
Default problem with ecu swap zc
my friend has a zc crx and was running an 88 si ecu and the car worked fine. so the other day he bought an 88-89 integra ecu and put it in and the car didnt start then he put the old si one he was using back in and the car still didnt start what could be the problem???
Old Feb 21, 2003 | 12:14 PM
Hondasaurs's Avatar
Default Re: problem with ecu swap zc (chirp2hrd)
Chances are he has an 86-87 Teg ECU. They look the same, plug in the same, but will not run in an 88-91.
Does the ECU have a big "X" shape press in it? It goes across the whole ECU, it bubbles out. If his ECU has this it willl not work....wrong year.
[Modified by ZC_CRX, 4:15 PM 2/21/2003]
Old Feb 21, 2003 | 01:43 PM
chirp2hrd's Avatar
not only that he put the 88-91 si ecu back in and it wouldnt start either
Old Feb 21, 2003 | 01:55 PM
EFsleeper's Avatar
will the car crank at all? more info is needed for everyone to add suggestions on what to check
Old Feb 21, 2003 | 03:36 PM
chirp2hrd's Avatar
Default Re: problem with ecu swap zc (EFsleeper)
it cranks but wont start could it be the distributor?
Old Feb 21, 2003 | 03:47 PM
Malgerus's Avatar
Check for fuel and spark.
Old Feb 21, 2003 | 10:17 PM
chirp2hrd's Avatar
Default Re: problem with ecu swap zc (Mr. S)
how should i check for spark the plugs?
Old Feb 22, 2003 | 12:01 PM
Hondasaurs's Avatar
Check the ECU fuse in the engine compartment. Its in that plastic box on the passanger side fender.
Old Feb 23, 2003 | 02:32 PM
chirp2hrd's Avatar
Default Re: problem with ecu swap zc (ZC_CRX)
checked all fuses and they are good what else could be the problem??
Old Feb 23, 2003 | 03:33 PM
Outsane's Avatar
check for spark..
pull a plug, and connect back to the spark plug wire and hold it on a metal surface of the car while cranking the engine over..if you see sparks you have spark..
then after thats done stick your nose down the open spark plug hole and smell for gasoline...and you should know if your getting fuel..
b17 turbo
May 7, 2008 11:28 PM
Captain Anarchy
Aug 9, 2006 04:44 AM
momentoftruth03
Nov 8, 2004 04:54 AM
lude97dude
Jan 26, 2003 10:14 AM
SiRWannabe
15
Jun 7, 2002 08:59 AM
